Hi mate, as far as i am aware even with the hilow set all the way to its shortest length you still cant get the cone and hilow out at the same time without removing the upper control arm first. i did mine recently and had to remove the upper arms to get them out.
in saying that, i had some people tell me they had gotten theirs out without removing the arm, but i couldnt work out how.
once you have the cone and hilow out of the car, put it in a vice and give it a few good wacks with a BFH. i also used some large flat bladed screwdrivers to pry it off the hilow. obviously this is much easier out of the car and in a vice.
good luck.
