It is currently Fri Jul 25, 2025 1:02 pm
 Post subject: Polycarb Window Options
PostPosted: Thu Mar 17, 2011 5:21 pm
I've got perspex in the side windows and rear one piece door on my Van. It scratches easily and fogs up over time, meaning it has to be periodically replaced. What apart from glass are the alternatives? Is Lexan any more durable, or are there other polycarbon options around?
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Thu Mar 17, 2011 5:24 pm
Lexan is better but nothing is as good as glass.
PostPosted: Thu Mar 17, 2011 6:42 pm
What's road legal?
I'd assume "plastic" in any window except the front would be acceptable, depending on the quality and grade of the "plastic".
PostPosted: Mon Mar 21, 2011 5:49 pm
Looks like the best stuff is Lexan Margard. Light, strong, won't scratch easily dues to its special protective coating. Can be bought in a Mini kit from:
http://www.plastics4performance.com/Lex ... 8-301-633/
Or City Plastics in Adelaide do a 2240 x 1220 sheet for $420 +GST.
3mm panel is about 1/3 the weight of equivalent glass sheet.
Slide
