It is currently Sun Jul 27, 2025 11:01 pm
 Post subject: running lean?
PostPosted: Mon Mar 21, 2011 7:09 pm
Hi,
my friend has recently acquired a mini clubman with a 1275 engine (we believe it has been bored out a little, not sure how much).
Anyways it has the 1.5inch carb and it only seems to run well with the choke out. With the choke in it seems like its not getting enough fuel.
Is this carby too small for this engine, or would it just need adjustment?
Another thought i had is that there could be a vaccum leak?
Ryan
PostPosted: Mon Mar 21, 2011 9:19 pm
Give Ash some flowers Nick .
If you put your finger in the throat of the carb and lift the piston by about 1/16 to 1/8" how does the engine respond?
If the engine dies then it is too lean, if the engine's rev's pick up and run faster it is running too rich. If it slightly rev's up and then settles back down again then it is about right at idle. All this should occur when holding the piston in the carby up. This does not take into account if the engine has a needle that is really wrong with it.
PostPosted: Mon Mar 21, 2011 9:38 pm
ok and how do i adjust it if it's too lean?
PostPosted: Mon Mar 21, 2011 9:58 pm
there's a big nut under the carb, unscrew it a couple of flats with your fingers
PostPosted: Mon Mar 21, 2011 10:13 pm
sweet so there shouldnt be any major issues with the carby then :) I'll give it a go!
PostPosted: Mon Mar 21, 2011 10:19 pm
Only unless it has the incorrect needle fitted.
PostPosted: Tue Mar 22, 2011 4:45 am
Mods rock!
It does sound like ^^ might be the fix, but it could also be a bit of dirt in the bottom of the jet (that's what the needle slides in to).
