It is currently Tue Jul 29, 2025 6:39 pm
 Post subject: Fuel Pumps
PostPosted: Thu Jul 21, 2011 10:23 pm
What should i go with? i need a low pressure pump to keep up with a 1400 with a 45 weber? anyone have preferred/desired pumps with reasoning as to why? Approx price would be good to if you can remember.
Bill
PostPosted: Thu Jul 21, 2011 10:45 pm
I use a Facet square red one, 2.5-3.5psi, it works just fine with both my 1360 (~125HP) and 1412 stroker (114HP). It's mounted on a Mini centre exhaust mount screwed to the subframe. This shuts it up good, can't hear it with engine running. These pumps are cheap and go just about forever.
Carby is a 45 Dellorto, no fuel pressure regulator needed.
Around $90 or so, Karcraft sells them too.
Users browsing this forum: Bing [Bot] and 98 guests
