It is currently Mon Aug 04, 2025 2:08 am
 Post subject: Rear Hilos
PostPosted: Thu Mar 24, 2011 4:32 pm
Supercharged
anyone find the rod length too short?
 Post subject: Re: Rear Hilos
PostPosted: Thu Mar 24, 2011 4:44 pm
Mods rock!
I have in a couple of instance found them too long (these were the Mini Spares ones).
Not enough in the Hi-lo Bolt to compensate?
Can you fit factory washers between the knuckle joint and rod?
PostPosted: Thu Mar 24, 2011 4:46 pm
Have your cones collapsed?
PostPosted: Thu Mar 24, 2011 7:12 pm
Supercharged
these ones.
http://www.minispares.com/Product.aspx? ... 500&title=
i thought the rear ride height was okay, didnt have a look at the cones tho.
PostPosted: Thu Mar 24, 2011 7:43 pm
This space for rent
Likewise -- the ones I got from Karcraft a year or so ago were a cast iron sod to get into the back of my van with new cones...
PostPosted: Thu Mar 24, 2011 7:44 pm
use an old pair of hydro rods...
PostPosted: Thu Mar 24, 2011 7:49 pm
Mods rock!
I have done that and had them bend. They should work OK but it has happened a couple of times.
PostPosted: Thu Mar 24, 2011 8:46 pm
dunno - I had them on 3 daily drivers for 10 years or so all up, always the same set, never an issue
PostPosted: Thu Mar 24, 2011 8:51 pm
I've done this in two of my mini's no problems so far. (approx 5 years of use)
67' Matic
73' S
