SU Books https://www.ausmini.com/forums/viewtopic.php?f=2&t=69681 |
Author: | Hanra [ Thu Mar 24, 2011 9:48 pm ] |
Post subject: | SU Books |
Im quite competent with stripping/re-building HS type SU's, but Ive just got myself a HIF44 that I would like to perform a complete rebuild on. Which SU book covers the HIF series in detail? |
Author: | GT mowog [ Fri Mar 25, 2011 3:55 am ] |
I have an SU Workshop Manual that does cover them quite well and silly as it sounds, Haynes have one on Webers (Weber Carburator Manual) that also covers them quite well (and a number of other carbs). |
Author: | Hanra [ Fri Mar 25, 2011 6:42 am ] |
Do u know the name your SU book GT? Is it still available? |
Author: | Angusdog [ Fri Mar 25, 2011 9:00 am ] |
Link here to a rebuild of a turbo HIF44. Probably the same as a normal one, which is why I'd bookmarked it. |
Author: | Hanra [ Fri Mar 25, 2011 10:05 am ] |
Sweet. Thats a nice little tear down. Would still be good to get a book. I noticed the dashpot spring in this is huge in diameter compared to the HS2. Its really soft to... like really.. Is there a better set up to use for the dashpot spring? I reckon this will cause issues with the piston lifting to quickly. |
Author: | coops [ Fri Mar 25, 2011 12:48 pm ] |
£11.19 delivered (amazon uk have free delivery to aus until 15th may) http://www.amazon.co.uk/Carburettor-High-Performance-Manual-Speed/dp/1845840739/ref=sr_1_1?ie=UTF8&qid=1301021115&sr=8-1 Just check here to see if what you want is in the books contents page. http://books.google.com.au/books?id=CTz2EAp2ua8C&pg=PA27&dq=su+hif44&hl=en&ei=FAGMTcuNHorBcf2d-JkK&sa=X&oi=book_result&ct=book-preview-link&resnum=3&ved=0CDcQuwUwAg#v=onepage&q=su%20hif44&f=false Ok so have to spend £25 for free shipping http://www.amazon.co.uk/gp/help/customer/display.html/?nodeId=200627060 |
Author: | GT mowog [ Fri Mar 25, 2011 1:10 pm ] |
Hanra wrote: Do u know the name your SU book GT? Is it still available?
SU Carburetters, by the SU Carburetter Company, a subsiduary of Leyland Motor Corporation. I am unsure if it is still available, I've had mine close on 30 years now. As mentioned above ^^, the Weber Book is also a good one, is still available and is a later publication than the SU one and has bits & pieces not covered in the SU Book. <EDIT> I have not looked in this book, but could be worth a look http://www.amazon.co.uk/Carburettors-Tu ... pd_sim_b_2 Those books coops has listed ^ could be quite good from a performance side of thing but not too sure on just the basic overhaul & maintenance type of stuff. |
Author: | coops [ Fri Mar 25, 2011 1:20 pm ] |
The book I listed has rebuild prcedures. Chapter 14: SU repair and rebuild, like I said check the google book link I provided to look at the content page. |
Author: | GT mowog [ Fri Mar 25, 2011 2:38 pm ] |
coops wrote: The book I listed has rebuild prcedures.
Chapter 14: SU repair and rebuild, like I said check the google book link I provided to look at the content page. Well, there you have it. Coming from Des, it would be a bit 'dry' but very informative. Do you have this book coops? |
Author: | coops [ Fri Mar 25, 2011 8:46 pm ] |
No I don't but I ordered it today so I can let you know if it is any good when I get it. |
Author: | Hanra [ Fri Mar 25, 2011 9:04 pm ] |
Please do. Im mainly after detailed info on the HIF series. Thanks. |
Author: | GT mowog [ Sat Mar 26, 2011 6:16 pm ] |
coops wrote: No I don't but I ordered it today so I can let you know if it is any good when I get it.
I'd be interested to get your thoughts on it when you get it ![]() |
Author: | coops [ Sat Mar 26, 2011 6:41 pm ] |
Yes I will report back, remind me if I forget. ![]() |
Author: | Hanra [ Sat Mar 26, 2011 6:42 pm ] |
coops wrote: Yes I will report back, remind me if I forget.
![]() What were we talking about? |
Author: | GT mowog [ Sat Mar 26, 2011 6:49 pm ] |
Hanra wrote: coops wrote: Yes I will report back, remind me if I forget. ![]() What were we talking about? It always comes back to ladies......... |
