HS4 Twin Carbs Fuel inlet https://www.ausmini.com/forums/viewtopic.php?f=2&t=69751 |
Author: | brett [ Mon Mar 28, 2011 8:46 am ] |
Post subject: | HS4 Twin Carbs Fuel inlet |
i Guys, Starting to reassembe the Cooper S Bits and pieces while waiting for the Body Shell to arrive home. Just need some guidance, I have checked the manuals but they say nothing. I have previosly had the fuel pipe go straight into the fuel bowl thing, then it went via an other pipe to the 2nd carb. Looked a bit crapy, so I ordered the original metal pipe and looks much neater. Now do I have to block the little copper pipe that used to be connected to the fuel line? CHeers Brett |
Author: | simon k [ Mon Mar 28, 2011 10:49 am ] |
Post subject: | Re: HS4 Twin Carbs Fuel inlet |
brett wrote: Now do I have to block the little copper pipe that used to be connected to the fuel line?
see if you can guess what happens if you don't - it would normally be connected to another carb that would receive full fuel pressure I'd dig up another float bowl lid that doesn't have the extra pipe - looks neater |
