It is currently Sat Jul 26, 2025 9:21 am
PostPosted: Fri Apr 01, 2011 9:56 am
I've burnt through my 2nd exaust manifold gasket in about 200 miles. This is the gasket between the head and the extractors. Centre exhaust port burnt through - Maniflow extractors on a 1275, standard size ports.
Last gasket change i did all the right things:
cleaned all the faces on extractors and head
made sure everything was flat (cleaned up with a flat file)
new standard type gasket (grey with metal insert) installed dry
ensured everything was seated properly when doing up.
retighted nuts after warming up
retighted nuts after a drive
Looking for ideas, what are others doing with success?
VHT Copper coat?, smear of hi-temp silastic? anything else?
Novelty of doing gasket changes is wearing off.
Diecast
PostPosted: Fri Apr 01, 2011 10:17 am
did you measure the thickness of the manifold flange on the extractors against the inlet manifold flange and make sure the washers were thicknessed accordingly?
I had that trouble and I think I ended up getting the extractors ground flat and the same thickness top & bottom
PostPosted: Fri Apr 01, 2011 10:33 am
1. Maniflow LCBs- the middle flange is not flat, or in the same plane as the end ones. Usually. Cure- grind/file it flat.
I bolt it to an old head with no gasket, then check around with a .002" feeler gauge.
2. There are better manifold gaskets- Unipart do a turbo one with metal rings on the exhaust ports. See Mini King or Karcraft.
PostPosted: Fri Apr 01, 2011 12:01 pm
every thing looked ok as it went back together, inlet manifold and extractor flanges same thickness etc
metal ringed gasket sounds good. Installed dry? or with any type of goop/copper coat/loctite etc.
Thanks for the help guys
PostPosted: Fri Apr 01, 2011 12:10 pm
Mods rock!
Might seem un-related but is your ignition timing right?
PostPosted: Fri Apr 01, 2011 12:41 pm
Ignition is ok, starts easy, no pinging, runs strong to 6500, fuel mixture, engine temperatures good, RC40 exhaust etc. If i was having issues here, then yes ignition timing might be an issue. Seems to me to just a direct mechanical issue
Both gasket problems have occurred at the end of track days. 1st Gasket failed after 3 track days, 2nd gasket failed after 3x sessions at a track day.
PostPosted: Fri Apr 01, 2011 1:01 pm
Just looked online and seen a picture of the turbo exhaust gasket, looks like it will do the job, thanks doc
PostPosted: Fri Apr 01, 2011 1:28 pm
I'd get out the verniers and measure all the flanges. A few mm either way will stuff things up. Make sure you use the proper thick exhaust manifold washers and new nuts (don't cost very much from minis.com.au, in fact I think they sell a whole set).
Manifold gasket mounted dry. I've never had problems with std gasket when done properly...
Lillee - 1969 Morris Mini K
Users browsing this forum: Bing [Bot], ken@miniauto and 86 guests
