It is currently Sun Jul 27, 2025 4:10 pm
 Post subject: Booster mounting
PostPosted: Wed Mar 30, 2011 9:00 pm
Is anyone able to post picks of where to mount a booster, i need to give them to my mechanic so we can orgainse the best position to place it. i have a '78 clubby
i am going to have it on the drivers side ifrint of the master but need orientation and height?
thanks guys
 Post subject: Re: Booster mounting
PostPosted: Wed Mar 30, 2011 9:15 pm
basically it goes in the only place and way it'll fit... assuming you're fitting a VH44 type, the nose points forwards
PostPosted: Wed Mar 30, 2011 9:33 pm
In a Clubby I have seen them mounted backwards, or also mounted up high near bulkhead, pointing across the car. Makes engine removal easier.
PostPosted: Wed Mar 30, 2011 10:18 pm
Best place to mount a brake booster is on e-bay :-)
I won`t mention the "other" way to mount a booster :-)
PostPosted: Thu Mar 31, 2011 12:09 am
behind the dash, under the wheel arch.. there are loads of ways..
or the correct way.
PostPosted: Thu Mar 31, 2011 4:32 am
They also say the booster should be angled slightly up at the nose to assist with bleeding as you can see in this pic....
PostPosted: Thu Mar 31, 2011 5:41 am
This is how they are fitted to a Clubbie GT
But the problem you face is that the Brakes in your 78 model are a Tandem (split Front & Rear) Circuit set up. This is an ADR requirement.
You can Boost Fronts only or get a Rover set-up.
Gee, this was some time ago, Simon
PostPosted: Thu Mar 31, 2011 10:46 am
I've no idea what you're talking about! looks the same to me:
:oops:
PostPosted: Thu Mar 31, 2011 11:27 am
If you have a 78 clubby, I'm not sure you can mount it where most of these are. You'll have the washer bottle and brake bias valve in the way. You may need to get a bracket to lift it higher. I suppose you could move the washer bottle, though.
PostPosted: Thu Mar 31, 2011 4:48 pm
Oh, yeah, I see it now (says the blind man....)
PostPosted: Thu Mar 31, 2011 8:36 pm
...but if it's a '78 doesn't it have a tandem system anyway (or was that only the 1275 LS).
Justin
PostPosted: Thu Mar 31, 2011 8:51 pm
Yes it does, but you can servo the front circuit only, in hard braking that does all the work anyway.
I've done it on a few cars over the years.
PostPosted: Fri Apr 01, 2011 6:25 am
How are these hooked up to a tandem system?
Like this?
I have a problem.. apparently
PostPosted: Fri Apr 01, 2011 7:10 am
Like this?
Yeap. Only very small difference is that on the Rover Proportioning Valve they only have one outlet for the front brakes and then use a union on the front right flexible hose take off in the subframe, very similar to the Ozzy single circuit set up. Will make no difference though, just a detail.....
<EDIT> The booster on the Rover Set up works on the Pushrod in to the Master Cylinder (like 99% of modern Cars), where as the single circuit booster (eg VH44) works in the hydraulic circuit on the output from the Master Cylinder.
Another way of doing it is BMW & Merc. style - two hydraulic boosters, yeah, like there is lots of room to do that.........
<2nd EDIT> I don't like (hate in fact) those Proportioning Valves! There are better (factory) ones.
PostPosted: Fri Apr 01, 2011 10:28 am
It is that set up as it diagram above. the washer bottle has been moved by previous owner to suit a booster in the area infront of the master. thanks all for your help
