NG wrote:
michaelb wrote:
My Cooper s won't start without the choke so I think you are lucky it starts at all.
And yes mini's need to warm up, best to start driving as soon as possible as leaving it idle for too long is not good for the longevity of the engine life
Best to connect your choke I think
yep for sure, will order parts tomorrow.
interesting, i have always been told to warm up a car till it moves the needle one notch.
i was always under the assumption that the most engine wear on a engine is start up & cold driving? thats any car?
what is everyones view on this?
I was always taught best way to warm up a car is to just start driving it. However until it has warmed up to normal you would take it easy i.e not rev real hard or full throttle, or labour engine up a hill.
I think you would find most car handbooks would be along these lines.
I can't believe people who start up a dead cold engine and start revving it's guts out, just be gentle, it's stone cold and everything in the engine is a loose fit. Letting a car idle in the driveway for 10 mins is not a great idea either.
From Page 42 of Mini Handbook TP 757e
Regarding the choke on the SU. Usually the first portion of the movement is just fast idle, a screw acts on the thottle and increases the idle speed.
The second stage of the knob pulls down on the jet and moves it away from the needle causing an increase in fuel.
On an SU it's actually not technically a "choke" as air is not restricted. It's more a "fuel enrichment" control.
My starting procedure is choke out to 2nd notch, clutch in, no thottle, start up. Then almost straight away adjust choke in to get a idle of about 1300.
Within about 5 mins of driving the choke can be gadually pushed in, at this stage you are really only adjusting idle speed anyway.
....also from the Handbook:
