Torque setting
https://www.ausmini.com/forums/viewtopic.php?f=2&t=69892
Author:  jethro [ Sat Apr 02, 2011 4:29 pm ]
Post subject:  Torque setting
Hi Everyone, please can someone give me the torque setting of the camshaft sprocket nut. I have a gregories service and repair manual and it gives some torque settings but I can`t find a setting for the camshaft nut. The crankshaft pulley bolt it says torque to 95 Nm, so I would think the camshaft nut may be in the region of 85 - 90 Nm, just guessing though.
Jethro
Author:  simon k [ Sat Apr 02, 2011 4:42 pm ]
Post subject:  Re: Torque setting
Jethro
yeah, same as the crankshaft pulley nut, 60lb/ft (what's a Nm? :P)
Author:  jethro [ Sat Apr 02, 2011 5:17 pm ]
Thanks Simon, Nm is Newton metres, the metric equiv of lbs ft, but you knew that. My Gregories tells it in Nm or lbs ft so I am just telling you how it is in the book. 60 lbs ft ( or 81 Nm ) it is then.
Jethro
Author:  simon k [ Sat Apr 02, 2011 7:01 pm ]
Jethro
sorry, I was prompted to check the torque - it is 70lb/ft (95Nm) - like you said for the pulley bolt... though I did say "same as the flywheel pulley nut", but I said "nut", so mayeb two wrongs cancel each other
Author:  jethro [ Sat Apr 02, 2011 7:36 pm ]
70 lbs ft it is then
