Wiring / alternator https://www.ausmini.com/forums/viewtopic.php?f=2&t=69893 |
Author: | Fiji [ Sat Apr 02, 2011 4:38 pm ] |
Post subject: | Wiring / alternator |
Hey just need to know where this wire starts in my loom. Finishing at my alternator it needs to be replaced yellow/brown wire. ![]() ![]() Cheers guys. |
Author: | GT mowog [ Sat Apr 02, 2011 5:21 pm ] |
The Brown / Yellow wire run up to the Instrument Cluster on a Clubbie / Rover or Speedo on a roundie. It goes to the IND (red) warning lamp. |
Author: | DTrain [ Sat Apr 02, 2011 5:29 pm ] |
http://www.niksula.hut.fi/~mdobruck/siililand/mini/diy/6/images/miniwire.gif |
Author: | Fiji [ Sat Apr 02, 2011 5:42 pm ] |
Post subject: | . |
Cheers GT. Want to keep the colour the same . Supercheap?? If not I'll scab some from work on Monday but it won't be the same colour. |
Author: | GT mowog [ Sat Apr 02, 2011 5:47 pm ] |
DTrain, that's handy. Fiji, try supacrap and all the other usual suspects, You should be able to get Brown OK, but Brown with a Yellow Trace might be a bit hard to come by. You could also go down the wreakers with some side cutters, don't have to look for a Mini specifically, but just about any Ford, Holden or English Car will have a Brown / Yellow wire. |
Author: | Fiji [ Sat Apr 02, 2011 6:17 pm ] |
Post subject: | K |
Dtrain that helpful for future ref. Thanks Solid idea Gt I was hoping to go out to Lillee's joint tomor see what was going on I'll run through a few wreckers see what I can pick up. Cheers lads. |
Author: | gafmo [ Sun Apr 03, 2011 12:20 am ] |
Yep I got two Looms from Pick & Payless + the Original and cleaned them up and took the Best from the lot. You shouldn't have to much trouble getting a Brown with Yellow trace there. I always looked for the pommy cars first (Range Rovers also) as they are easier to get the full length out of |
Author: | Fiji [ Sun Apr 03, 2011 4:41 pm ] |
Post subject: | Normal? |
![]() Is it common practice for those wires to be all soldered together. I'm think not. Y/Br (burnt) runs to my alternator, it's not ind though. Brown to my solenoid +. the two bottom ones look to run under the dash .. Ignition I think. The wires soldered above are the green from my alternator to the yellow from my speedo. [/img] |
