Hydro Pump
https://www.ausmini.com/forums/viewtopic.php?f=2&t=69898
Author:  Haydn [ Sat Apr 02, 2011 8:44 pm ]
Post subject:  Hydro Pump
Any threads/posts on how to make a hydro pump?
Cheers. Haydn
Author:  sgc [ Sat Apr 02, 2011 10:35 pm ]
Post subject:  Re: Hydro Pump
Cheers. Haydn
If you can get one, look no further than http://www.ausmini.com/forums/viewtopic.php?t=59552.
Last time I checked the place we got the grease pumps were out of stock, but compared to the alternative hand-held grease pump (if you can't make the alternative pedal-box-master-cylinder solution) it's absolutely brilliant.
Author:  Minifreak_brg67 [ Sun Apr 03, 2011 8:16 am ]
I made one using a brake master cylinder off a trailer brake set up it looks a bit rough but it works really well
Author:  goodie [ Sun Apr 03, 2011 9:56 am ]
I made one the same as the grease type shown here, the chrome fitting i bought from a tyre service, ( $35 ), they use them for putting water into tractor tyres.
I have not used mine as yet, so not sure how it will go, will try soon. I'm sure others on here have made the same. http://www.austinamericausa.com/
Author:  simon k [ Sun Apr 03, 2011 10:25 am ]
mine's just an old brake master cylinder
Author:  Mick [ Sun Apr 03, 2011 12:51 pm ]
Still enjoying my grease pump made unit. The only problem I have had from the pump is the non-return ball valve at the bottom of the tank sometimes refuses to open on the uptake from all the pressure driving it into it's seat, but a light tap on the top is all it needs. Just a rap from a screwdriver is enough.
I drained the pressure just last week to alter the nose up-nose down trim on the hydro system. The nose drooped way too far so I tried a couple of washers under the knuckles on the front. Worked nicely!
Author:  sgc [ Sun Apr 03, 2011 12:54 pm ]
I have the same problem with mine, it gets relatively little use these days and whenever I do I find the ball sticks as well. I just blow mine with compressed air and it works perfectly 8)
Author:  Mick [ Sun Apr 03, 2011 12:56 pm ]
Try just a tap on the top next time, it's all it needs I think to get the recalcitrant little bugger moving..
Author:  Haydn [ Mon Apr 04, 2011 4:29 pm ]
Many thanks for all you replies Chaps.
But as D' Harry says 'gots to know you limitations'..
So with that, i certainly know mine.
Er..... can anyone who lives in Melbourne, loan/hire me a pump?
If i streeeeeeectched myself I'd probably make one but i really just need to get the car on the road so if anyone can help I'd be very thankful.
cheers.
Haydn
Author:  Lillee [ Mon Apr 04, 2011 5:28 pm ]
Has anyone baught one of these and are they any good?
http://cgi.ebay.com.au/NEW-Hydragas-Hyd ... 27b983dde5
Author:  BBY755 [ Mon Apr 04, 2011 9:54 pm ]
Wow,
Looks like the one I made with help from ausmini using a grease gun and $5 valve fitting but without the gauges!
Works a treat! :D
Author:  sgc [ Mon Apr 04, 2011 10:29 pm ]
Whereabouts are you in Melbourne?
Author:  Haydn [ Tue Apr 05, 2011 12:14 am ]
Rowville
Author:  sgc [ Thu Apr 07, 2011 1:54 pm ]
OK, well Haydn now has my grease-pump unit so he'll have his car pumped up in no time :D
Author:  Haydn [ Thu Apr 07, 2011 4:36 pm ]
Yes, and many thanks to Simon
Will give full report when job is done.
H
