Re-painting a painted mini. https://www.ausmini.com/forums/viewtopic.php?f=2&t=69907 |
Author: | sociallydisabled [ Sun Apr 03, 2011 1:56 pm ] |
Post subject: | Re-painting a painted mini. |
Hi guys, After a very long dormant period, I have pulled the mini out of hibernation, and for a couple of reasons I have decided to re-paint it. 1. I no longer want it this colour. 2. Some parts I never painted so I have stuff all chance of matching the colour. So, my question is, how far do I have to rub back to re-paint if I am already happy with the body work I have previously done? Last time I painted: -2k hi-fill primer. -Acrylic velocity red pearl. -clear coat. I have started sanding back to primer and metal in some places, but am wondering if this is really necessary? I will be re spraying primer and acrylic top coat. Cheers guys!! |
Author: | Phat Kat [ Sun Apr 03, 2011 2:49 pm ] |
Post subject: | Re: Re-painting a painted mini. |
sociallydisabled wrote: Hi guys,
After a very long dormant period, I have pulled the mini out of hibernation, and for a couple of reasons I have decided to re-paint it. 1. I no longer want it this colour. 2. Some parts I never painted so I have stuff all chance of matching the colour. So, my question is, how far do I have to rub back to re-paint if I am already happy with the body work I have previously done? Last time I painted: -2k hi-fill primer. -Acrylic velocity red pearl. -clear coat. I have started sanding back to primer and metal in some places, but am wondering if this is really necessary? I will be re spraying primer and acrylic top coat. Cheers guys!! Hello ![]() Are you painting it again using Acrylic? If so... to be totally honest.... and its not dodgy so don't get the wrong idea, it is infact common practice... if it doesn't need sanding back to bare metal.. don't bother. I'd just key the old paint (using 600grit paper) lay down 1 or 2 coats of acrylic primer, then put down the new colour. Honestly, that would be fine. If you took it to a shop, most of the time that's all they'll do if you tell them you want to paint it another colour. The reason I stress ACRYLIC primer, is because 2k primer is harder... as a result, if you lay down the hard 2k primer over the top of the soft acrylic base, the new paint will chip easier... acrylic primer won't give this problem. |
Author: | Super-mini [ Sun Apr 03, 2011 3:23 pm ] |
yeah just give it a good key, edd china does it all the time on wheeler dealers |
Author: | sociallydisabled [ Sun Apr 03, 2011 4:54 pm ] |
Yeah it will be acrylic again. Only this time im leaning towards a non metallic/pearl colour so it's easier to patch up. Cheers guys! Takes alotnof work outta the respray! |
