brake setup 7.5 or 8.4? https://www.ausmini.com/forums/viewtopic.php?f=2&t=70006 |
Author: | minideluxe [ Thu Apr 07, 2011 6:24 pm ] |
Post subject: | brake setup 7.5 or 8.4? |
Another info gathering exercise for me. I am going to change the drum to disc but wanting to know (if there is any) which setup is better 7.5 or 8.4. At this stage i know it's the case of wheels your going to run ie 7.5 for 10" where 8.4 is too big so you go to 12" but what else? also which kits/brands are recommended? |
Author: | Harley [ Thu Apr 07, 2011 6:48 pm ] |
Pick your wheel size then use the factory AP brakes. Simple and about as cheap as it can get. ![]() |
Author: | Hunter2 [ Sat Apr 09, 2011 1:37 pm ] |
My preference would be 7.5" discs with 10" wheels...which are likely what your Mini came with if drum brakes. Mind, if I was installing a fire breathing, earth consuming power unit, I might like to be better able to stop...so, 8.4" discs. |
