It is currently Wed Jul 30, 2025 10:04 am
PostPosted: Sat Apr 09, 2011 12:20 pm
I started my clubman up today and noticed it is running a little rough, it idles nice, and revs flat out nicely, but holding stable rpm with 1/4 throttle or whatever it is really lumpy.. Like it's miss firing but the fact that it revs freely makes me wonder if it is.. Anyone know what it could be?
Oh, it's a 998 with a 1.5 inch s.u on a water heated manifold. Extractors blah blah..
Sean
Potato
PostPosted: Sat Apr 09, 2011 2:03 pm
Hi Sean,
Sounds like you have pretty much the same mini as mine - 998, 1.5" SU, water heated manifold, extractors.
You say it idles nice, revs high nice, but lumpy in between?
I'd be placing my bets on the piston - it may be jamming when you only use part throttle, but full throttle 'un-jams' it. Try taking the piston out, giving it a bit of a clean and check the needle and jet. It could also be the choke sticking - just give the jet a little push up and see it it moves.
How does it go when accelerating or decelerating? If it loses power on acceleration, I'd check your dashpot oil - it may be too low of too thin. If it's only having problems when the throttle is steady, this won't be the problem.
It could be timing or perhaps your rockers need adjusting, but the carby is the first place to start.
PostPosted: Sat Apr 09, 2011 3:30 pm
have a look & see what distributor you have, the 29D type has a common problem where the base plate (vac-Advance) mech wears & lets the points open & close as vac-advance system tries to work on light throttle
an easy check is to take the vac hose off the distributor (or carby) & block up the hole to the carby, & then drive it again to see if the surging has stopped
if that stops the surging then the distributor is the problem
if you don`t have a 29D type dissy then disregard all what i`ve typed & replace your points maybe :-)
PostPosted: Sat Apr 09, 2011 8:00 pm
how old is the fuel in it?
Users browsing this forum: Bing [Bot] and 77 guests
