It is currently Tue Jul 22, 2025 8:13 pm
PostPosted: Thu Apr 14, 2011 11:35 am
Hey guys, I have a universal wiring kit which I am currently hooking up, one of these puppies: http://www.ezwiring.com/wiring_harness.html
Anyway its all very straight forward since all the wires are labelled, Im just having trouble with the alternator. I have two wires to hook up and they are labelled, alternator exciter and alternator power.
My alternator is a Bosch from an EA falcon so I have the S, L and B terminals.
I have the B hooked in to the starter solenoid with a heavy gauge wire. Would I be right in thinking I have to hook 'alternator power' to the B, piggy-back the B to the S post and connect the exciter to the L post?
Cheers for the help.
Edit:
Here is more or less the poor instructions which were provided with the kit, the charge section is towards the end.
http://www.clparts.com/pdfs/ez_wire_wm.pdf
So... I'm Seifer
PostPosted: Thu Apr 14, 2011 12:22 pm
Sorry i cant help, but i would love to see some pics of the fuse box, and your install if you dont mind?
I stumbled across these yesterday!
I have a problem.. apparently
PostPosted: Thu Apr 14, 2011 2:45 pm
Mods rock!
I've not used Alternators with Terminals marked as yours, however, it appears that the S Terminal is a sense for the Regulator and is connected to B+ve similar to one of the Lucas Alternators (16 ACR?). I would suggest connecting this Terminal to the Solenoid rather than the Alternator Output Terminal, that way the internal Regulator will adjust to Battery Voltage rather than Alternator Output, since there will be some (small) voltage drop in the Output Wire between the Alternator and the Solenoid.
The L Terminal connects to the Warning Lamp (with the other side of the Lamp also connected to B+ve).
http://forums.turbobricks.com/showthread.php?t=1069
Covertableminis (Tony) might know more.
PostPosted: Thu Apr 14, 2011 4:34 pm
No worries, Ill take some shots and do a mini write up I guess.
i didnt get any photos of it out of the box but now its almost installed will have to do.
So... I'm Seifer
PostPosted: Thu Apr 14, 2011 5:41 pm
Thanks, im mainly interested in how it looks in the car, and what the fuse box looks like!
Does it come with everything to basically rewire the car?
 Post subject: EA Falcon Alternator
PostPosted: Fri Apr 15, 2011 6:32 am
The Bosch alternator on an EA falcon has
S =sensing .
L + lamp
B+ + Battery.
The S terminal can be connected to the B+ itself, But if it is connected to a positive At the fuse box it will sense the demand for charge better.
The L just goes to the Ignition /Battery warning lamp.
Also remember that the EA falcon Alternator is capable of pushing out 85 Amps and you will need to use two 6 mm cables in parallel for the B+ as one 6mm cable on it's own can only carry 50 amps and it will get a bit warm and cause a voltage drop.
If you got a second hand EA one, make sure you wash all the power steering fluid out of it !!! Most of them copped a lot of it.
"Let us remove your "SHORTS"
