It is currently Sun Aug 03, 2025 2:49 pm
 Post subject: Quick Paint Question
PostPosted: Wed Apr 20, 2011 10:30 am
Im about to do some rust repair around my door; lower part of the skin, under the hinges and on the hinge A-Panel.
Ill be taking the door off for repairs and priming, however being a metallic paint, Id rather paint the door on the car. This will however mean that the area under the hinges will just be primer tho. Is there any issue with this or should i rethink my strategy. Im hoping it will just be touching up and not a full respray of the area.
So... I'm Seifer
PostPosted: Wed Apr 20, 2011 10:36 am
Paint the areas under the hinges before you assemble the doors onto the body.
Simple.
:D
PostPosted: Wed Apr 20, 2011 3:35 pm
What harley said!!
Paint, let dry, refit! Thats in basic terms anyway.
mooo, I'm a pig!
PostPosted: Wed Apr 20, 2011 7:30 pm
yea what they said, plus ...... don't have the hinge gasket on when you have it reasembled for paint, even space the hinge out a bit with some washers so there is not as much of a hard edge around the hinge when you paint it. :wink:
Dusk Blue
1964 850
Users browsing this forum: Bing [Bot], drmini in aust and 101 guests
