Reducing pedal effort with pads?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=70231
Author:  Harley [ Tue Apr 19, 2011 10:51 pm ]
Post subject:  Reducing pedal effort with pads?
Before I go and install a booster into my car, just wondering what are the softest compound 8.4 brake pads available that anyone can suggest for me?
I don't really have the weight to throw at my brake pedal constantly so want to give myself a bit more confidence in stopping.
:D
Author:  wild_willy [ Wed Apr 20, 2011 8:59 am ]
Try the EBC Ultimax black pads. Work well without a booster on 7.5 discs for daily driving but dont try them for motorsport
Check that these are the right pads before you buy
http://cgi.ebay.com.au/MINI-MINI-MOKE-7 ... m20b8ae77f
Author:  Super-mini [ Wed Apr 20, 2011 4:11 pm ]
i think the blackstuffs are rubbish, i have to apply ridiculous force to get it to slow down with em on.
i read somewhere that the pedal effort is high on purpose, to stop you from locking the brakes.
Author:  VulcanBB18 [ Wed Apr 20, 2011 4:46 pm ]
I would imagine the stock factory type will be about the easiest on the pedal.
If you're really after a "modern/soft" pedal then a booster is about the only way to go IMHO.
cheers,
Jacob
Author:  EST-071 [ Wed Apr 20, 2011 7:53 pm ]
I have had a set of blacks in my car for 2 years ( about 30k kms ) and drive it every day in traffic. I also do some spirited driving in the lower blue mountains. I have not had brake fade in that time and I have locked the fronts on several occasions. As for pedal effort, I found no difference between standard pads and blackstuff pads.
IMO you can not go past blacks in a daily driver.
Cheers Pete
Author:  drmini in aust [ Wed Apr 20, 2011 8:00 pm ]
I ran blackstuffs in Barney and I currently have them in mine too.
As Pete said they are hard to beat in a daily, but PROVIDED you don't go on sprited runs down them thar hills... you will fade em and they'll go tata until they cool. Been there, done that, a few times.
Greenstuffs stop lots better than blacks when hot, but when cold with no servo you have to stomp on em harder.
Author:  GT mowog [ Wed Apr 20, 2011 8:07 pm ]
Sounds awefully like your discs are glazed.
Author:  Beanie [ Thu Apr 21, 2011 9:30 am ]
Yep disks are glazed as well as the pads ... i never had mine fade on the track but they were crap until they became warm dont know if this was from being heat cycled or what ..
i would and do use these
http://www.minisport.com.au/prod547.htm
Beanie
Author:  Lillee [ Thu Apr 21, 2011 9:44 am ]
Completely the opposite experience with my black stuffs. New discs, new pads, stops on a dime and can lock em up if stomping hard
Author:  GT mowog [ Thu Apr 21, 2011 6:41 pm ]
Remember, when fitting any new pads and / or disc rotors (or fresh machined ones) that they need to be bedded in carefully before using them hard. Same with shoes and drums.
Author:  Super-mini [ Thu Apr 21, 2011 6:59 pm ]
i remember thinking the blackstuffs were acceptable for town use when i first installed them, but they were still very easy to fade so i cant recommend them and wouldnt use them again.
i'm not used to driving a mini anymore, so i guess the pedal effort isnt as bad as i think :lol:
Author:  poeee [ Fri Apr 22, 2011 10:51 am ]
The EBC blacks were better in my 1275 LS with 8.4's than they are in my van with 7.5's... I mean in regards to pedal pressure. Having said that... I used to drive the LS daily, and now I drive a modern car daily.
