Electric pressure sensors for brake lights
https://www.ausmini.com/forums/viewtopic.php?f=2&t=70250
Author:  mtsmini [ Thu Apr 21, 2011 12:35 pm ]
Post subject:  Electric pressure sensors for brake lights
Re the electric sensor that sits on the drivers side in a bolt through a banjo in the engine bay.
Is that sensor supposed to sit up proud or screw right down onto the top of the bolt?
Mine's seems to sit high with a space between the bottom of the sensor and the banjo bolt. Meaning that the thread must be tapered?
So:
1. It's supposed to screw down on top of the banjo bolt OR
2. It's supposed to sit up high.
Author:  Convertible Mini [ Thu Apr 21, 2011 1:14 pm ]
Post subject:  Brake lioght switch
The brake light switch... If Brake lights work and switch or it's fittings don't leak... DO NOT TOUCH IT.
Author:  Wombat [ Thu Apr 21, 2011 1:15 pm ]
Sits high but there is a copper washer under the shoulder against the banjo
Author:  mtsmini [ Thu Apr 21, 2011 1:34 pm ]
Its 9 to 10 I'm talking about. Rest is ok.
Space is between 9 to 10. I note that there is no washer shown on the diagram.
Never mind DON'T TOUCH IT. I've rebuilt my whole brake system including making up all the hard lines.
It's just I thought that the sensor should sit down hard against the banjo but it doesn't want to. Either inside the bolt or the sensor thread must be tapered?
Author:  GT mowog [ Thu Apr 21, 2011 6:38 pm ]
The original switch sits high, not sure about replacements / aftermarket ones though.
