Mick wrote:
Convertible Mini wrote:
Yes you can test the Volt Stabilizer's output with a Multimeter But You Will need an analogue one. You will see the pointer going up and down but will not exceed 10 volts. If it is an Electronic Type stabilizer it will be steady on 10 Volts. A modern Digital Multimeter on an old bimetallic Stabilizer will show a lot of change too quick and you will not be able to read it.
I reckon if you have a capacitor it should show a level charge of a digital multimeter. Perhaps a relatively large cap and a 1k resistor in parallel across the output of the voltage stabiliser?
Mick, the cap would charge to the peak voltage produced by the voltage reg, in the case of the original vibrating type, that would be the same as the input voltage.
It is a 'problem' that I have given some thought to and don't really have a simple answer for, when using a digital meter. As Convertable Minis saƮd ^ about easiest way for most of us is with an analogue meter. A bit harder to come by these days. I thibk Dick Smiths still have one model and Jaycar recently re-introduced one.
http://www1.jaycar.com.au/productView.a ... rm=KEYWORD
OK, some some guys here will probably now wonder which to get, digital or analogue?
If you were to buy only one meter, I'd say the analogue. They are more tedious to use than an auto-ranging digital, but far more universal.
