It is currently Sat Jul 26, 2025 6:58 pm
 Post subject: Unusual front end noise
PostPosted: Mon Apr 25, 2011 10:33 pm
Hey guys i know the whole nose description isnt very good but i'm after a bit of help with what i should be looking for when i pull the car apart tomorrow.
going around a corner today at full lock right, i heard what i can only describe as a clunk, accompanied by the steering wheel jumping to the right, then springing back again.
I thought what the F was that to myself then drove back around the block to see if there was anything on the road i could have hit that had caused this reaction.. . didn't find anything
So i let it go and went to the shops, same thing turning into the shops full right lock, clunk!. thought stuff it got my shopping and went home. on the way home (5k) didn't ever hit full lock right and didn't ever hear a clunk.
so i put the car up on stands gave the wheel a shake around and checked to see if i was missing anything or if anything had come loose. nothing that i could find, wheel was solid
Thaught stuff it i'll find out what the hell this is and around 10pm went for another drive to the supermarkets empty carpark where i promptly put it into full lock both directions and drove in circles till my tyres started slipping. i've got yoko ao48's so they take a lot to slip.
anyway full lock left not a problem, full lock right, nothing until i got up a bit of speed and i could 'feel' that the tyres were having to fight a little bit then clunk, clunk, wheel jumps over and back again.
i haven't a clue what the hell it is, i'm thinking the steering is passing a pivot point or something to do with the cv is letting go/jamming up. i'm pulling it apart tomorrow to find out but if anyone has ideas or wants to come over and give me a hand/talk minis in Northcote i'm more than happy to hear any suggestions
Cheers all!
1962 850,Frog
PostPosted: Mon Apr 25, 2011 11:31 pm
sounds to me like a cv
engine conversion thread http://www.ausmini.com/forums/viewtopic.php?t=79201
build thread http://www.ausmini.com/forums/viewtopic ... xe&start=0
PostPosted: Mon Apr 25, 2011 11:37 pm
I am sure that this is not all, but check:
All ball joints, wheel bearings, wheel bearing retaining nut, u-bolts retaining rack, steering rack ball joints, front tie rod rubbers, drive shaft universal joints, cv joints, lower arm rubbers, upper arm bearings, knuckle joint, wheel nuts, shock absorbers.
Be methodical and check one thing at a time. Reference your workshop manual.
michael
PostPosted: Mon Apr 25, 2011 11:45 pm
Have not had this problem...but the wheel "jumping back" caught my eye. I'm guessing a rack & pinion problem with a damaged/missing portion of the worm gear.
Have had a CV cage break up...going straight ahead...but after the sounds of imminent doom on turning at all. Lost my balls too.
PostPosted: Tue Apr 26, 2011 11:40 am
cv cage is busted over one of the ball bearings. turned the wheel round up on the jack and felt the ball moving around inside the rubber boot....that cant be good.
anyway pulled out the bearing and the bits of cage that had broken off which i'm guessing were getting jammed every now and then causing the clunk and pulling the steering wheel to the side on full lock.
now i'm one bearing down on a public holiday, worst easter ever! but hey at least its something i can fix fairly easily. thanks for the help everyone
1962 850,Frog
PostPosted: Tue Apr 26, 2011 11:58 am
maybe the massive box on the bonnet has caused suspension failure :o
Have a Nice Day.
PostPosted: Tue Apr 26, 2011 1:08 pm
MinisPlus
I've got a new in box drum brake CV here if you want one today...
How can it be rusty when it's covered in so much oil?
PostPosted: Tue Apr 26, 2011 1:18 pm
broken diff? similar sounding to when i broke mine
PostPosted: Tue Apr 26, 2011 2:47 pm
Thanks for the offer but i'm running 8.4" disks. gonna have to make some phone calls tomorrow i think.
Thanks 850man but i think its more to do with my "spirited" driving
anyway have a good week everyone and i'm sure i will be back on here as soon as the next issue shows itself :D
1962 850,Frog
 Post subject: Clunk..
PostPosted: Tue Apr 26, 2011 5:38 pm
THE WHEEL NUTS !!!
"Let us remove your "SHORTS"
