Heater Tap Blank https://www.ausmini.com/forums/viewtopic.php?f=2&t=70320 |
Author: | tracytracey [ Mon Apr 25, 2011 10:05 pm ] |
Post subject: | Heater Tap Blank |
If removing the heater should I blank the tap or connect the hose the to the bottom rad hose? Cheers. |
Author: | drmini in aust [ Mon Apr 25, 2011 10:07 pm ] |
In Tassie you could probably just blank it off, but if running a hose and no heater it's best to put it into the top hose. |
Author: | Morris 1100 [ Mon Apr 25, 2011 10:11 pm ] |
In Tassie in winter I would probably keep the heater! |
Author: | tracytracey [ Mon Apr 25, 2011 10:14 pm ] |
Thanks drmini, where can I get a top hose with a takeoff, I need to put in a new radiator as the current one has the heater hose coming up the front and I can't shut the bonnet properly. It is a 1275LS engine in a traveller shell if that makes a difference. |
Author: | tracytracey [ Mon Apr 25, 2011 10:16 pm ] |
Morris 1100 wrote: In Tassie in winter I would probably keep the heater! . The heater had no electrics just the water running through the matrix and it leaked.
Author: | drmini in aust [ Mon Apr 25, 2011 10:27 pm ] |
tracytracey wrote: Thanks drmini, where can I get a top hose with a takeoff, I need to put in a new radiator as the current one has the heater hose coming up the front and I can't shut the bonnet properly. It is a 1275LS engine in a traveller shell if that makes a difference.
You would probably need to make something up with a tee fitting. Or add another hose connection to the top tank (a radiator repair shop can do this). IMO a waste of time in Tassie as it's cool down there. |
Author: | mickmini [ Mon Apr 25, 2011 11:02 pm ] |
drmini in aust wrote: tracytracey wrote: Thanks drmini, where can I get a top hose with a takeoff, I need to put in a new radiator as the current one has the heater hose coming up the front and I can't shut the bonnet properly. It is a 1275LS engine in a traveller shell if that makes a difference. You would probably need to make something up with a tee fitting. Or add another hose connection to the top tank (a radiator repair shop can do this). IMO a waste of time in Tassie as it's cool down there. C'mon Kev, have you got ice in your veins? I lived through a couple of Tassie winters and I put a heater in for the first time so that the inside of the car was WARM for a change ![]() cheers michael |
Author: | drmini in aust [ Tue Apr 26, 2011 9:55 am ] |
We drove Barney round Tassie a while back in winter, NO heater... ![]() But yeah if it was my car, at my age I'd just stick a Clubby heater in it too. |
