It is currently Sun Jul 27, 2025 3:01 pm
PostPosted: Tue Apr 26, 2011 5:47 pm
Hi Guys.
I pulled my mini apart about 15 years ago and now that the rebuild is nearly done, I realise that a few bits that I need have gone missing. (Oh! Only just realised that now, have you?)
Where in Brisbane can I source a full set of new door and rear pocket liners for a 1969 Mk2 S? Do the UK ones from Newtons/Huddersfields/Mini Spares etc. fit? Does anyone know of an upholsterer (in Brisbane) who can accurately reproduce the door cards/trims?
Also, where can I get a set of the bespoke flange bolts and nuts for the steel uni's (hardy spicers)?
Thanks.
No decision is incorrect when made - but it does become apparent in retrospect...
PostPosted: Tue Apr 26, 2011 6:23 pm
The UK ones maybe from a MKI might fit, but I'm pretty sure Newtons are doing some Ozzy stuff. The ones from Huddersfeild are very nice, especially for the price but won't fit.
I am pretty sure Ozzy MKII Cooper is same as Mini K.
PostPosted: Tue Apr 26, 2011 6:32 pm
The hardy spicer flange bolts are easy enough to get locally or overseas:
http://www.minispares.com/Product.aspx? ... 323&title=
as are the specialised nuts:
http://www.minispares.com/Product.aspx? ... 009&title=
As for the rear pockets, If you like doing these things at home.. I found a good quality old pocket from an old wreck and made a cardboard pattern. This I outlined onto upholstery card and cut out. Once that was done it was simple to lay some spray glue and attach the vinyl over the top. I repeated this for the front pockets as well. They're identical to the originals.
PostPosted: Tue Apr 26, 2011 7:39 pm
Newtons only have the Australian ones (mk1.5) models. Mine are on the way! :D
 Post subject: Rear pocket liners
PostPosted: Tue Apr 26, 2011 8:40 pm
I have a few sets of of Leyland Mini S here if they are the same. Going cheap. But I am sure they will need to re covered/re trimmed a la Cooper S.
"Let us remove your "SHORTS"
PostPosted: Tue Apr 26, 2011 9:29 pm
High heel ninja
The pockets can be bought thru minispares in Sydney 02 9774 3366
Doogie
