It is currently Tue Jul 29, 2025 7:19 am
 Post subject: Tie Rod arm free spining
PostPosted: Thu Apr 28, 2011 9:27 pm
Hi guys, one of my tie rods are spinning, Any tips so I can get the nut back on?
Cheers Brett
PostPosted: Thu Apr 28, 2011 9:34 pm
Mods rock!
You mean the tappered spindle in the hole on the steering arm?
Put a bit of pressure on it from underneith with a jack.
PostPosted: Thu Apr 28, 2011 9:36 pm
Yep thats the one! Thanks!
Put a jack or something similar under the tierod end to put a little upwards pressure on it and it will lock up in the taper and allow you to do up the nut.
Hope this helps
