It is currently Sat Aug 02, 2025 3:23 pm
 Post subject: Horns
PostPosted: Mon Apr 25, 2011 10:30 pm
I was unsure of this... so I thought that I might ask here.
One of the connectors on the original horn in my car is broken. To get the car registered I swapped that horn over with the one from my other mini.
Now... are original Australia made horns easy to come by? or is it worth salvaging the original horn?
Once again I think that there is a debate in here about originality.. as I want to keep this car as original as I can.
If it is worth salvaging, is it easy to replace the connectors?
1966 Morris Mini Minor Saloon (Dot) - 1275 Auto - Mongrel
1968 Morris Mini Van (Ivan) - 998 Auto - Mongrel
1968 Morris Mini.Matic (George) - Original
1968 Morris Mini.Matic (Charlie) - Original
PostPosted: Tue Apr 26, 2011 1:14 pm
I am sure you will have no trouble finding another Australian horn, unless it is a Cooper 'S' horn you are after, they are very rare and attract a significant premium over a normal horn. Let me know if you need a Cooper 'S' horn, I am sure I can find one for you! :)
PostPosted: Tue Apr 26, 2011 1:22 pm
Cooper S horn??
What is the differance?
Specificaly for a 1969 S.
PostPosted: Tue Apr 26, 2011 1:27 pm
IndigoBlueCooperS wrote:
Cooper S horn??
Cooper S $tax... :lol:
PostPosted: Tue Apr 26, 2011 2:31 pm
The Morris 1100 horns are the way to go. :wink:
PostPosted: Tue Apr 26, 2011 5:34 pm
You shouldn't have any problem finding another horn. Many people swap them out, because they're rubbish :)
If it's just a connector on your horn, how hard can it be to fix?
PostPosted: Wed Apr 27, 2011 9:20 pm
You tell me.
Here is the horn connection area. One of the tabs has broken off.
Image[/list]
PostPosted: Wed Apr 27, 2011 9:29 pm
Meh- forget fixing that, go find another. Must be a zillion still about. :lol:
PostPosted: Wed Apr 27, 2011 9:30 pm
I would just clean it up and solder it back together. Bit of black paint and nobody would know!
PostPosted: Wed Apr 27, 2011 10:00 pm
You bet, loud enough to get the :shock: from some folks :lol:
Jacob
PostPosted: Wed Apr 27, 2011 10:05 pm
Jacob
You just need to fiddle with the screws to get the most out of them.
They are almost the same as the ones fitted to the Falcon GTs (like the Phase 3) it is only the wiring terminals that are different.
Nobody ever complained about the horns on them but when they are on a Mini they somehow turn useless. :x
PostPosted: Thu Apr 28, 2011 12:54 pm
Wiring by Lucas
David L
PostPosted: Fri Apr 29, 2011 10:51 am
If I was to replace the connector, how would I go about it? (besides getting a replacement horn)
PostPosted: Fri Apr 29, 2011 8:23 pm
maybe you should ask our resident X SPURT MR GT MOWOG HE KOWS EVERYTHING that you will need to know unless he is watching the football tonight
