It is currently Fri Jul 25, 2025 10:45 pm
 Post subject: metro turbo set up
PostPosted: Mon May 02, 2011 5:24 pm
Hey guys. Just wondering of a metro turbo disc set up can be modified to suit 10 inch wheels?
thanks nick
PostPosted: Mon May 02, 2011 5:37 pm
I think you're limited to 7 inchers
So... I'm Seifer
PostPosted: Mon May 02, 2011 5:49 pm
I think you need 12" wheels for the 8.4" metro turbo disc brakes
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon May 02, 2011 6:00 pm
Depends on your offset on the rims.
Or you could machine your discs down, modify your hubs and the grind your callipers down until they fit under your wheels. But for all that cost and effort you could just buy a set of cooper s discs and run them.
Simplify and add lightness
PostPosted: Mon May 02, 2011 7:28 pm
The 7.9" Set up fits with some 10" Rims.
PostPosted: Mon May 02, 2011 8:36 pm
ok thanks guys getting some for a good price, and anyway some new wheels would look nice. What sort of body mods are need for 12inch rims?
Thanks nick
PostPosted: Mon May 02, 2011 9:11 pm
Thanks Nick
depending on the wheel width & offset you may have to cut some of the front wheel arch.
PostPosted: Mon May 02, 2011 10:31 pm
i have 12 inch wheels with nothing cut but to do this i had to jack my car up using hilos doesnt look the best. so i recon best option is cut the guards if they dont fit but each to there own
PostPosted: Tue May 03, 2011 8:28 am
Performance Superlites in a 12x5 is what you need. They fit fine with standard brakes (I've used them on cars with 8.4's and spacer drums). Both standard Clubman flares (which are the same profile as MK2 Cooper S flares) and the yuck black plastic flares.
Metro hubs are different, just remember that. I believe you can run metro turbo calipers and rotors on Mini disc brake hubs?
PostPosted: Tue May 03, 2011 9:08 am
Cummon mate, only on the slack 8)
Yeap.
And not a good idea to use the Metro Hubs on a Mini.
PostPosted: Tue May 03, 2011 9:52 am
Will the 'offset' (offset probably isn't the correct term, where the wheel will sit) of the metro rotor be the same as the standard 8.4" Mini rotor?
PostPosted: Tue May 03, 2011 10:00 am
Fairly close, but the problem with the Metro Hubs is the King Pin Angle (this will tend to make the car dive off in an un-expected direction when the suspenion height changes ie, going over a bump) and the distance between the ball joints is greater. You'll also need adjustable arms to get the camber somewhere near what you want.
I have a heap of Metro Hubs here if you want them :D
The off-set is increased if you want vented discs as the drive flange needed is different to get it all to fit. If you have a look at some of the cars fitted with these, you'll notice the track is wider and the scrub is increased, along with wheel bearing load.
PostPosted: Tue May 03, 2011 6:13 pm
I can confirm metro hubs on a mini are freakin dangerous, even with every conceivable suspension part adjusted and holding my mouth just right. Couldnt believe how much better the car drives with proper hubs, actually steers where you want it to!
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Tue May 03, 2011 6:15 pm
You'd think, wouldn't you? I went to the expense of getting new disk hubs when I went to turbo vented disks. When I showed it to the certifying engineer, he said "Why didn't you use metro hubs? That's what all the other guys do?". I didn't want to get offside with him by telling him that they'll probably never get rid of the castor effects (can't remember why metro hubs don't work).
Then he pulled me up for running 1 degree negative camber! I'll wind it out for the cert, then set it up to what works best.
