It is currently Sun Aug 03, 2025 3:19 am
 Post subject: for the brains trust
PostPosted: Mon May 02, 2011 8:30 pm
I have a 1098 in one of my engine bays and it has an odd number on it. it starts with 10 but it end with B which is also on the build plate , so I am tipping is factory.
My guess is that it's a factory replacement after the first engine died before leaving.
Thoughts ?
PostPosted: Mon May 02, 2011 8:37 pm
I know that an S means the block was sleeved when new. But I have never worked out the B. I assume bearings or maybe bore.
My Morris 1100 finishes with a B and I have seen other motors in Minis with the same B on the end. It is on the ID plate so it can only be a factory thing.
PostPosted: Thu Jun 02, 2011 9:14 am
A bit late but I have found the answer. The "B" on the end of the engine number refers to the gearbox, specifically who and where the gears were made.
The B stands for Borg Warner and these gears were made in Australia by them.
Woo hoo I finally nutted it out (with the help of some technical bulletins from Winabby)
PostPosted: Thu Jun 02, 2011 10:34 am
My Cooper S block has a S stamped on the back of the Block. Any ideas? :shock:
PostPosted: Thu Jun 02, 2011 10:50 am
I wrote this earlier..
But that applies to the engine number. Where is the S stamped on yours?
PostPosted: Thu Jun 02, 2011 11:00 am
From memmory bottom left hand coner on the rear on the lip where it bolts to the Gearbox
