It is currently Mon Jul 21, 2025 4:16 pm
 Post subject: Smiths gauges
PostPosted: Fri May 06, 2011 7:48 pm
Hi everyone, to all you gauge gurus out there, I would like some info on Smiths gauges namely a minispares SIB 122 MG tacho and a Speedo. I think my present tacho runs off the distributer, so if I get the minispares tacho is it a simple case of just hooking up the same electric wire as on the present tacho to the new tacho ?? Now with the speedo, I know the calibration may need adjustment but are the connections at the rear of the smiths speedos all the same, so that my cable will clip straight into the new smiths gauge ??
Jethro
