It is currently Fri Aug 01, 2025 10:51 pm
 Post subject: Gearbox ID
PostPosted: Mon May 30, 2011 9:57 pm
Clearing the shed and came across a 22G382 M1100 gearbox. Is it a 3 speed or 4 speed synchro and is it worth keeping. Has a busted diff output shaft.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Mon May 30, 2011 10:04 pm
A 22G382 should have started life as a Mini 850 3 syncro magic wand with B-type gears.
PostPosted: Mon May 30, 2011 10:20 pm
Probably not really worth keeping then! I am sure someone would have a use for it.... seems a shame to tip it!
PostPosted: Tue May 31, 2011 9:34 pm
Have stripped it today and kept the common parts to the 22G1128 4synchro box. Case is now just a resting place for a spare motor.
