It is currently Sun Aug 24, 2025 6:13 pm
PostPosted: Sun May 15, 2011 9:48 pm
this one, or any earlier version - http://www.sucarb.co.uk/ProductDetail.aspx?id=32041
I'd like to know what the compressed height of a HIF44 type dashpot spring should be - apparently it's on page 158 :lol:
PostPosted: Mon May 16, 2011 1:33 pm
I have an older version at home, will have a look tonight for you.
Kevin
PostPosted: Mon May 16, 2011 1:59 pm
awesome, thanks :D
PostPosted: Mon May 16, 2011 5:40 pm
Simon - I have the 7th edition - August 1993 (and the SU Midel catalogue 1974).
On page 176 it has the HIF Service and Repair Guide that occupies 3 pages. Nothing there about compressed height of the spring that I could see.
Page 114 describes piston springs. It has a table with 10 springs listed by colour and for each spring shows Type (A or B), Load at Length (e.g. light blue spring is 2.5 ozs and 2.625 inches) and the part number (AUC 4587).
Do you know what colour your spring is? Is this the information you are after?
I can scan the pages and email to you if you wish.
PostPosted: Mon May 16, 2011 5:46 pm
Here you go :) -
HIF Springs | Load at length | Part No.
Red | 4.5oz 1.530in | AUD4355
Yellow | 8oz 1.530in | AUD4398
Green | 12oz 1.530in | JZX1088
Kevin
PostPosted: Mon May 16, 2011 7:14 pm
thanks Doug, that is what I want.... but rathcoole has it :D
rathcoole wrote:
Here you go :) -
Kevin
thanks Kevin, that's exactly what I was after :D
much shorter measuring point than I imagined, Des Hammill's book shows a HS type spring compressed at about 2.5", but no measurements
PostPosted: Mon May 16, 2011 7:46 pm
Your welcome 8)
Kevin
PostPosted: Mon May 16, 2011 7:49 pm
My earlier book has all the info except it does not say what models it is referring to. :lol: :x :roll:
PostPosted: Mon May 16, 2011 8:14 pm
Mods rock!
rathcoole wrote:
Here you go :) -
Kevin
That's quite kind of Rathcole to post that up, but be aware Simon, that the springs compress further than this. This is only for checking the spring tension, thats what the 'weight' i in front of the measurement eg at a compressed length of 1.530" the Green Spring exerts 12 Oz force.
PostPosted: Mon May 16, 2011 9:30 pm
yep, well aware of that GT - I have a few springs and would like to see what they are, I would also like to fiddle with non-SU springs from the local spring shop. I wanted that measurement so I can compare apples with apples :)
PostPosted: Tue May 17, 2011 6:45 am
Mods rock!
No worries. Just from your original post it sounded like the fully compressed length you were after. Search is your friend (as they say)
http://www.ausmini.com/forums/viewtopic ... ht=springs
PostPosted: Tue May 17, 2011 9:57 am
well there I go - I missed that thread when it was current, I would have remembered it.
case closed :)
Users browsing this forum: No registered users and 143 guests
