Callin wrote:
Hi guys,
No rear tail, brake, number plate light or binnacle lights.
Anyone have any ideas?
Your post is a little bit unclear, but I think your rear indicators are working ok?
If so, then the problem for your rear park lights is found in front of the speedo binnacle in the engine bay (up near the window wiper actuators).
There's a 4 way bullet connector up there which has three wires going into it. One is from the light switch, the next is goes to the front park lights, and the last goes to the rear park lights and number plate illumination via the plug GT speaks of. One of your wires is loose up there. Its the only source for the rear parks and number plate. If the front is working then the light switch is fine.
I'm unsure of the brake light problem, but check the brake light switch to be sure of the connection there. It might have been like that for a little while and unnoticed.
