air hose from blower to windscreen vents - where to get it https://www.ausmini.com/forums/viewtopic.php?f=2&t=70763 |
Page 1 of 2 |
Author: | Ryan1980 [ Tue May 17, 2011 7:15 pm ] |
Post subject: | air hose from blower to windscreen vents - where to get it |
where do i buy this locally , as well as the fittings? im in perth. bunnings, repco?? |
Author: | Mick [ Tue May 17, 2011 7:29 pm ] |
I got some from a local shop over here called the purple pig...but I am also told that washing machine drain hose is the right size and shape. |
Author: | Ryan1980 [ Tue May 17, 2011 8:07 pm ] |
not my washing machine! |
Author: | Mick [ Tue May 17, 2011 8:09 pm ] |
Ryan1980 wrote: not my washing machine!
Maybe not, the lint would blow out all over the windscreen for months. But if you get it new, its cheap and available... |
Author: | Ryan1980 [ Tue May 17, 2011 8:39 pm ] |
lol no i mean i checked the hose on my washing machine - its not the same size, too skinny |
Author: | Morris 1100 [ Tue May 17, 2011 8:41 pm ] |
Ryan1980 wrote: lol no i mean i checked the hose on my washing machine - its not the same size, too skinny
Buy a bigger washing machine? here is a link for http://www.purplepig.com.au/ |
Author: | MiniPete [ Tue May 17, 2011 8:45 pm ] |
Depends on the make, I install them for a job, and there are many, many diameters ![]() |
Author: | Ryan1980 [ Tue May 17, 2011 9:58 pm ] |
ok looks like im off to see a washing machine repair place tomorrow then! |
Author: | 1275LS [ Tue May 17, 2011 10:55 pm ] |
Supercheap et al have 50mm corrugated aluminium tubing in black for $15 or so. Should look the part. |
Author: | Convertible Mini [ Tue May 17, 2011 10:58 pm ] |
Post subject: | Vent Pipe |
If you go to a Laundromat they have bigger washing machines there! Just a thought. |
Author: | goodie [ Tue May 17, 2011 11:25 pm ] |
Have also heard of somebody that used vacuum cleaner hose as well. |
Author: | crisonic [ Wed May 18, 2011 1:54 pm ] |
Post subject: | Heater hose |
Go to your nearest Godfreys Vacuum cleaner store if you are in Victoria and ask for 32mm flexible hose . There is the el cheapo stuff and the good stuff . For the good stuff ask for the black Electrolux flexible one. The cheap stuff kinks and feels like it would colapse easily. Otherwise any Vacuum cleaner store should be able to help you If you want the genuine cardboard light grey stuff for you concourse fanatics then I believe that you might find that it was used on some early Volkswagens It is known by its brand name Kopex tubing. I think the VW stuff was 38mm which means if you use that you have to use a reducer to make it fit the vents . Half an hour on the lathe fixes that |
Author: | BBY755 [ Wed May 18, 2011 4:28 pm ] |
Check this out! And the price! ![]() http://www.retrominisltd.co.uk/index.ph ... 4g02d2bd80 |
Author: | 4myego [ Wed May 18, 2011 4:33 pm ] |
I got mine from the local lawn mower shop. Its the exact size of the Victa mower air breather hose. And a lot cheaper than the one they were selling from Purple Pig. |
Author: | TUCK3r [ Wed May 18, 2011 10:23 pm ] |
i used the piping from xf falcon from exhaust to airbox.15 bucks cheers dan |
