It is currently Thu Aug 21, 2025 9:40 pm
PostPosted: Wed May 18, 2011 11:53 am
In the process of making a hydro pump, turns out that what I thought was a clutch master cylinder is a 0.7" brake master, although it was being used as a clutch master.
What rebuild kit do I use?
Looking at the pics on the minisport page ( http://www.minisport.com.au/category9_5.htm ) looks like I have a combination of the kits ie groove & no groove on body !! looking at the existing setup I will need the cup & ring seal (on piston) but the seal at the top of the spring is the one in question.
Is there any reason it won't work for my hydro pump
PostPosted: Wed May 18, 2011 5:28 pm
The ones with the groove have two seals with holes in the middle.
The ones without the groove have one seal with a hole and one cup seal.
Your one looks like the one without the groove.
You don't really need the valve on the end of the spring.
Is there a good brake place nearby? They will have the rubbers and they will be very cheap, probably only a couple of dollars.
If I was using it for a hydro pump I would just clean up the bore and reuse the rubbers. (actually that is exactly what I did with my pump!)
PostPosted: Wed May 18, 2011 8:25 pm
My first hydro pump was a second hand Clutch cylinder, an Ozzy Lockheed type with the Plastic Tank, made it easy to keep a check on the level. Worked for over 10 years. Every now and then, I'd flush it through with metho just to keep it working. I always wanted to put a bigger tank on it, but never got around to it.
PostPosted: Thu May 19, 2011 8:22 am
Thanks for the feedback
what does this valve do?
Users browsing this forum: No registered users and 185 guests
