First honest instructions
https://www.ausmini.com/forums/viewtopic.php?f=2&t=70818
Author:  Wombat [ Fri May 20, 2011 7:20 am ]
Post subject:  First honest instructions
Haynes would have said "remove adjuster"
The adjusters I just bought off GT say "Lever, saw,chisel or drill off the existing adjuster" :shock: :lol: - Something tells me it's not going to be easy :?
Author:  swiftden [ Fri May 20, 2011 8:15 am ]
that's funny at least it gives you a realistic view of what to expect
Author:  Angusdog [ Fri May 20, 2011 9:13 am ]
Every mini owner should have a thermic lance in their toolkit.
Author:  GT mowog [ Fri May 20, 2011 12:14 pm ]
Post subject:  Re: First honest instructions
Well,after you fix the grinder :wink: , cut the tops off them, then drill them off. Fiddely, yes, but shouldn't be hard.
I do actually have one of them. Great for piercing steel of any thickness, eg, I can put a hole through the head of rail track in less that 2 seconds. Will also cut concrete! The rods are a bit dear though.
Oh, and I wouldn't recommend it for safe cracking, what ever was inside wouldn't be much good after hitting the safe with it.
Author:  Mick [ Fri May 20, 2011 3:24 pm ]
I get to use one of those (called a broco cutter over our way) from time to time. They are good fun.
Author:  crazy bob [ Fri May 20, 2011 6:40 pm ]
I agree, everyone should own a Broco Cutter. If you cant fix something with a hammer you can always destroy it with the broco, then pretend the problem never existed.
