It is currently Fri Jul 25, 2025 8:38 am
PostPosted: Wed May 11, 2005 4:51 am
I stripped my 1310 to a bare block on the weekend, and have extracted an unknown cam. It has no markings in the usual places.. so all I can supply is the lobe dimensions.
[Low = narrowest width of lobe, High = tallest width of lobe]
INTAKE:
Low - 0.97" / 24.6mm
High - 1.249" / 31.73mm
Cam intake lift = 0.297" or 7.13mm
EXHAUST:
Low - 1.009" / 25.66mm
High - 1.293" / 32.84mm
Cam exhaust lift = 0.28" or 7.18mm
It has 1/2 inch wide lobes, spider drive, and has "113" stamped into the timing chain nut end. I have not yet measured the duration.
Can anybody give me any info on this cam with the above numbers???
PostPosted: Wed May 11, 2005 6:44 am
Nearest I can recall-
Might be a Tighe 112? see profiles in here- http://tighecams.com.au/cars.htm
PostPosted: Wed May 11, 2005 10:25 am
well there you go... mine's a tighe 240 - we sent my head specs to them after we ported and flowed it, and they sent a cam back to suit it. Was awesome till the head cracked itself to uselessness
Users browsing this forum: Bing [Bot] and 100 guests
