Pump action window washer
https://www.ausmini.com/forums/viewtopic.php?f=2&t=70930
Page 1 of 2
Author:  ryan [ Thu May 26, 2011 6:36 pm ]
Post subject:  Pump action window washer
Hi all,
Today at rego check, I went to pump the washers to spray water and ....nothing.
I had a quick look and the lines were bone dry (its been a year since I last used them). I pumped and pumped but nothing came through?
Do I need to bleed the lines? When I take the tubes off the back of the pump it feels as though its sucking, but it was kind of hard to tell at the time.
Ryan
Author:  Monaco [ Thu May 26, 2011 7:25 pm ]
Check the little valve on the end of the hose that is in the washer bottle?
Author:  ryan [ Thu May 26, 2011 7:48 pm ]
the hose just drops straight into the bottle. No valve.
Author:  phillb [ Thu May 26, 2011 8:14 pm ]
Yeah I think it needs that little one way valve. Probably fell off last time you filled it.
I think one from an aquarium shop might work.
Author:  ryan [ Thu May 26, 2011 9:16 pm ]
Ha, I will check in the bottom of the bottle?
What do they look like?
Author:  Monaco [ Thu May 26, 2011 9:55 pm ]
Like an upside down mushroom with a flat head! :wink:
Author:  Morris 1100 [ Fri May 27, 2011 4:26 pm ]
They usually look something like this...
Author:  goodie [ Fri May 27, 2011 6:25 pm ]
I'll have to go and check mine now :shock: it hasn't worked since i've owned it :!:
Author:  Morris 1100 [ Fri May 27, 2011 6:30 pm ]
You need to get all the air out of the pump for best results. It is a probably a good idea to remove the pump so you can turn it to get the air out while pumping.
The washers on my 1100 stopped working a while back and I found that the hose on the firewall had been hit by the air-filter splitting the hose.
Author:  Monaco [ Fri May 27, 2011 6:50 pm ]
In reference to my last post: Maybe not a mushroom then! :lol:
Author:  slacko [ Fri May 27, 2011 6:53 pm ]
Where do the hoses go through the fire wall to the pump ?
Is there a certain hole there some were ?
is it below the parcel self ?
Mark
Author:  goodie [ Fri May 27, 2011 8:44 pm ]
G'day Mark, from memory when i done a wiring job on my ignition under the dash , i remember the tube coming in through the dash with the main wiring harness , and down to the pump. Definately not saying that this is the correct route for it.
Author:  slacko [ Sat May 28, 2011 6:48 pm ]
Thanks goodie , starting to put mine back together
Mark
Author:  ryan [ Sun May 29, 2011 10:01 pm ]
These are the two listed on the minisport website.
Mini windscreen washer one way valve (early cars)
[/url]http://www.minisport.com.au/prod716.htm[url]
and
Mini windscreen washer valve (sits in washer pump bottle)
[/url]http://www.minisport.com.au/prod1870.htm[url]
I imagine the bottom one is the one I need. Whats the top one for?
Does $15 seem a little steep?
[/url]
Author:  Monaco [ Sun May 29, 2011 10:59 pm ]
I look at it this way, if someone came to you and showed you the valve and said "if I give you $15 will you make me one of these?".....kinda makes it look like good value then! :)
