It is currently Fri Aug 01, 2025 1:11 am
 Post subject: Fuses in 1275 L.S.
PostPosted: Thu May 26, 2011 10:58 pm
I've hade a 30 amp fuse blow (may have been 30 years old)on the light circut. there is only the two fused circuts so i assume that it must use aa 30 amp fuse,but i don't want to burn wire's if its to high.I've looked thru the 3 manuals i have but no info on fuse size. So in sumery.What size should it be?Thanks.
PostPosted: Fri May 27, 2011 5:40 am
They did come with Fuses rated 30 Amp and while these are a fairly high rating, they are the correct ones to use.
The 1275 LS actually has 3 fuses. There are the ' standard' 2 in the fuse box, but there is also a 3rd In-line one almost buried in the Harness near to the fuse box. That is the one for the parkers and instrumnet illumination lamps.
PostPosted: Thu Jun 02, 2011 3:23 pm
I think the original fuse size was 35 amps, but I don't think you can get those anymore. Even 30 amps still seems a lot, there are a lot of wires in a Mini which will melt with a lot less than 30 amps going through them.
+ Too many other classics
