Need helpers Friday 17th Late June Brisbane https://www.ausmini.com/forums/viewtopic.php?f=2&t=70946 |
Page 1 of 3 |
Author: | brett [ Fri May 27, 2011 2:11 pm ] |
Post subject: | Need helpers Friday 17th Late June Brisbane |
Hi Guys, Just had a phone call from the panel beaters and they he wont let me take my shell home on a car trailer with out the wheels attached. In fear of damaging the paint work . So he has offered his hoist and work shop so we can simply drop the subframes onto the body, so I can roll it onto the trailer, I know its a long way off, and not sure the date, but if anyone can assist It would be appriciated! And I will let everyone know the date! Should only be a few hours work. ![]() Thanks Brett |
Author: | Mokesta [ Fri May 27, 2011 2:38 pm ] |
I'm in. Let me know the details. M |
Author: | Lockie91 [ Fri May 27, 2011 2:43 pm ] |
happy to help out, when needed ![]() |
Author: | Panthersteve [ Fri May 27, 2011 3:35 pm ] |
I'll help if available on the day. |
Author: | blue_deluxe [ Fri May 27, 2011 6:49 pm ] |
Ill help if im available |
Author: | TK [ Fri May 27, 2011 7:29 pm ] |
Might be able to help, keep me updated. |
Author: | MrFail [ Fri May 27, 2011 8:13 pm ] |
if i'm not stuck under mine i'd be keen to come along, probably not much help, but i might learn something. ![]() |
Author: | 850pete [ Fri May 27, 2011 9:16 pm ] |
Post subject: | help |
Would be happy to come along and help out, im no mechanical genius but being a painter I've worked around more fresh paint than I could poke a ratchet at! |
Author: | brett [ Fri May 27, 2011 9:57 pm ] |
Thanks guys! I will def keep you posted. Main things is before I can trailer it away is * Fit subframes ( with all the bits attached already) * Run Electrical cables I will try and do it the day before * Fit windows and door locks so they dont flap all the way home. Thanks so much guys! ![]() |
Author: | Morris 1100 [ Sat May 28, 2011 1:44 pm ] |
Brake pipe are fitted before the subframes. ![]() |
Author: | Lockie91 [ Sat May 28, 2011 1:57 pm ] |
Morris 1100 wrote: Brake pipe are fitted before the subframes.
![]() yes to right this! I found this out the hard way once. ![]() |
Author: | Morris 1100 [ Sat May 28, 2011 2:02 pm ] |
Lockie91 wrote: Morris 1100 wrote: Brake pipe are fitted before the subframes. ![]() yes to right this! I found this out the hard way once. ![]() And don't pinch the battery cable.... ![]() |
Author: | Lockie91 [ Sat May 28, 2011 2:25 pm ] |
Morris 1100 wrote: Lockie91 wrote: Morris 1100 wrote: Brake pipe are fitted before the subframes. ![]() yes to right this! I found this out the hard way once. ![]() And don't pinch the battery cable.... ![]() shhhhhhhh ![]() |
Author: | NAV [ Sat May 28, 2011 3:37 pm ] |
Lockie91 wrote: Morris 1100 wrote: Lockie91 wrote: Morris 1100 wrote: Brake pipe are fitted before the subframes. ![]() yes to right this! I found this out the hard way once. ![]() And don't pinch the battery cable.... ![]() shhhhhhhh ![]() Well don't put it on a public forum then ![]() |
Author: | Lockie91 [ Sat May 28, 2011 3:49 pm ] |
NAV wrote: Lockie91 wrote: Morris 1100 wrote: Lockie91 wrote: Morris 1100 wrote: Brake pipe are fitted before the subframes. ![]() yes to right this! I found this out the hard way once. ![]() And don't pinch the battery cable.... ![]() shhhhhhhh ![]() Well don't put it on a public forum then ![]() it will help others later down the track ![]() Doesn't really bother me Matt, last comment to Morris was sarcasm. ![]() |
Page 1 of 3 | All times are UTC + 10 hours |
