998 onto a magic wand gearbox https://www.ausmini.com/forums/viewtopic.php?f=2&t=71016 |
Author: | min16i [ Tue May 31, 2011 8:39 pm ] |
Post subject: | 998 onto a magic wand gearbox |
Evening All, I emailed Graham Russell the other night to get some pricing on pistons and things for my 998 rebuild and he mentioned that I'd need to mod the gearbox a touch to get it to fit. Is there anything else I need to be aware of? Can you use a magic wand with a later gearbox? Sorry about the noob questions. It's a bit more straight forward in Landcrab world ![]() Ian |
Author: | drmini in aust [ Tue May 31, 2011 8:46 pm ] |
As long as the crank and rods miss the flange and centre web of the case there should be no other mods. You can fit a magic wand diff housing and shifter to a 4 synchro remote box- just check the sizing and alignment of the diff bearing housing bores when bolted up. Remove the 2 dowels if you have to. Alternatively you can fit a `puddin stirrer' shift to a stock remote box's diff housing. It works and looks much like the magic wand, and was used on Mokes and pov pack cars from 1969-73 approx. I have pics, will add them here if/when I find them. ![]() ![]() ![]() |
