It is currently Fri Jul 25, 2025 10:09 pm
 Post subject: clubman tacho
PostPosted: Wed Jun 01, 2011 7:13 pm
hi
i have a problem with my tacho, tacho is not working. ive checked power at the back, the white wire with a bullet female terminal has power , the yellow wire spade female terminal has power and the black wire female spade terminal has nothing im guessing that is a earth. can anyone explain how the tacho should work and what i should check for to get a idea on how my tacho should work.
cheers dan
PostPosted: Wed Jun 01, 2011 10:51 pm
Tomboss Breweros
Just looked at my BL manual and it only shows the printed circuit plug, not the guages.
I know that the white female bullet is common with the coil -ve so when it's running that should be pulsing (LED test light will show this up).
So if the yellow has power and black has nothing, while running i'd try jumping an earth to the black and see what happens.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Jun 02, 2011 7:06 am
so i should get a signal from white wire?because it has just 12v with a test light no flasing.
cheers dan
PostPosted: Thu Jun 02, 2011 7:31 am
Mods rock!
Could you tell us if it has stopped working or if it never worked?
There are two types of stock Clubbie Tacho's. The early ones senced the ignition impluses were wired in series with the +ve to the coil and so had an 'in' and an 'out' on the tacho. The later ones just senced the voltage impluses from the points.
Check with your meter / test lamp that you have a good earth on the tacho by putting it straight across the yellow and black wires.
If your tacho has the single bullet type connector on the back of it, it sences voltage impluses from the points. The white wire that connects to that, the other end of it should connect to the points side of your coil. If this is the type of tacho you have, there is a good chance that this is the problem with it.
If the tacho is the earlier 'in-series' type and the car runs, then the tacho is karput.
PostPosted: Thu Jun 02, 2011 10:34 pm
the tacho did work but now it doesnt and i have both type of tachos. in two types of clusters and both dont work anymore. should i have a on ,off signal from the white wire from the bullet terminal?
Cheers dan
 Post subject: Tacho Problem
PostPosted: Fri Jun 03, 2011 7:33 am
Perhaps it is time to change your faulty Printed Circuit ! Contact me if you need one. I am the source.
"Let us remove your "SHORTS"
Users browsing this forum: No registered users and 112 guests
