Cooper S drive shafts with pot joints
https://www.ausmini.com/forums/viewtopic.php?f=2&t=71053
Page 1 of 2
Author:  knuts2au [ Thu Jun 02, 2011 10:25 pm ]
Post subject:  Cooper S drive shafts with pot joints
Looking ahead at bits and pieces of our "Leyland" build up, i have a set of Cooper S disc bakes and drive shafts, but the gearbox has "pot" joints not uni joints. Which end do i change the gearbox to uni's or the drive shaft to pot joint ends?
Block, crank and pistons are back from the machine shop, and the body shell is being blasted in the morning, so things are starting to move finally!
PeterN :D
Author:  drmini in aust [ Thu Jun 02, 2011 10:30 pm ]
Probably cheaper to go with pot joints for a road car- Cooper S diff output shafts/drive flanges and Hardy Spicer drive yokes are getting rarer and expensive.
Having said this I still run the Cooper S setups, because I have 2 sets of everything.
Author:  mattsmadmini [ Thu Jun 02, 2011 11:09 pm ]
:lol:
Author:  Giddyup [ Fri Jun 03, 2011 4:44 pm ]
I'd be inclined to go the hardy spicers. They do come up occasionally and if you think they are expensive now, they certainly won't get any cheaper as time gets goes by. I've seen a few complete sets on ebay, and plenty of broken sets (ie g'box output flanges only or hardy spicer joints only). Do it once and do it right.
Author:  1071 S [ Fri Jun 03, 2011 9:26 pm ]
"Leyland"...so we're not looking at originality....
UJ bushes are a bit bigger (which may spread the load) but then the CV is much smoother (one of the design breakthroughs for the Mini was the use of the outer CV) .... Most of the uni type joints I've seen have been damaged/deformed by the hammering needed to remove/insert new UJs.
I'd just use whatever I had... (although I ditched my own UJs....)
Cheers, Ian
Author:  knuts2au [ Fri Jun 03, 2011 10:45 pm ]
Ok i'm guessing then that the i can replace the "pot's" with yokes on the gearbox, ie they are interchangable on the diff splines.
Author:  1071 S [ Sat Jun 04, 2011 12:56 pm ]
The splines are the same but you will need the matching diff side covers... as I said, the UJ bushes are bigger.... although I believe the similar looking "auto box" UJs use the same bushes as the pot joint??????
Cheers, Ian
Author:  miniobsessed [ Sat Jun 04, 2011 2:38 pm ]
If you want to change your gearbox outputs to 'S' type unis you need to change the diff output shafts, diff side covers and diff output flange plus all the little bits and pieces required to secure the whole lot together... You then need the corresponding flange and yoke to slide onto your 'S' type drive shafts.
Author:  knuts2au [ Sat Jun 04, 2011 7:12 pm ]
Mmmm ok then, what about fitting the later style ends to the CooperS drive shafts?
Author:  drmini in aust [ Sat Jun 04, 2011 8:05 pm ]
Won't fit- splines are different and so are shaft lengths.
Author:  justminis [ Sat Jun 04, 2011 9:28 pm ]
To run the pot joints and the Cooper S brakes, all you need to do is to fit the S CV joint (outer) to the end of the pot joint driveshaft. It all fits together. Really wouldn't bother changing the diff output shafts etc to the S Hardy Spicer type, there is no gain. IMO, the pot joints are the better option, I run them on my race car with S brakes.
Author:  knuts2au [ Sat Jun 04, 2011 10:03 pm ]
Ok i was looking at the wrong end then, i just need to change the S wheel hub end onto the new driveshafts.
Thanks guys thats solved one problem, probably more to come lol.
Author:  simon k [ Sun Jun 05, 2011 7:46 pm ]
I was gonna say - there were some pretty out there suggestions :lol:
just use clubman driveshafts :D
Author:  Morris 1100 [ Sun Jun 05, 2011 7:51 pm ]
Clubmans? Are you sure?
Author:  drmini in aust [ Sun Jun 05, 2011 8:09 pm ]
Nooooooo, not the Clubman ones.. think `later'. :wink:
