It is currently Tue Jul 22, 2025 5:04 am
 Post subject: PCV valve
PostPosted: Fri Jun 03, 2011 10:14 pm
I just finished putting a pcv valve on my car. I think I did I correctly. Do I have to adjust anything, eg. Carbies, idle etc. Any tricks? Thanks. Getting ready for Hay.
Why don't people believe me when I say Arianca Tan will make a come back.
PostPosted: Sat Jun 04, 2011 8:09 pm
Should be no adjustments needed, unless you have a Weber and have fitted the valve to one inlet port only. Then, it's usual to richen the idle mixture slightly on that side only.
