It is currently Sun Aug 17, 2025 9:29 am
PostPosted: Tue Jun 07, 2011 2:32 am
Hey,
Just doing a bit of research for a race mini project I'm hoping to start quite soon.
searched every site I can find and tried ebay for engines
where do you guys find your engine's or blocks etc?
Thinking a 1275 a+ for a start.
Planning on doing a twin cam head conversion.
I know specialist components sell these as turnkeys. Anyone had any experience with these? are they worth the money or could it be done a lot cheaper done locally or done by myself and mechanically inclined friends?
Cheers for any help.
Cory
1975 Leyland Clubman -1320cc
 Post subject: A+ Blocks
PostPosted: Tue Jun 07, 2011 4:38 am
IF for racing... Just bare in mind that A+ blocks are stronger but heavier also.
"Let us remove your "SHORTS"
PostPosted: Tue Jun 07, 2011 7:51 am
A+ blocks in most ways are good, however, don't turn your nose up at a later non A+. The difference in strength is almost academic and lets face it, you're going to break a rod or crank way before you have any trouble or measurable difference with the block.
Remember too that the A+ was not designed to give better strength than the previous blocks, they were intended to be quieter :roll: that's why they spent 30 million pounds developing it :roll: (you'd think they could have developed a new engine all togther)
 Post subject: re aplus engines
PostPosted: Tue Jun 07, 2011 8:23 am
hi there cory
have plenty of the aplus engines in all forms,ie blocks,short and long engines
i am in melb but can freight anywhere around the country.
speak to matt reid on here about the twin cam kit as he does a kit also, he will give you rough costings so you can make a comparison,
cheers josh
miniimports
PostPosted: Tue Jun 07, 2011 11:59 am
How much heavier us the a+? I just read somewhere this was the better block for the k-series because it tiok heat better?
And josh, do you regularly have these? This is just a bit of homework while I raise the cash.but if you have regular stock that helps a lot. What's the going rate for a good condition long engine a plus? Cheers mate.
PostPosted: Tue Jun 07, 2011 12:18 pm
I too have been looking for a 1275 for an upgrade down the line, have looked everywhere to no avail.
PostPosted: Tue Jun 07, 2011 12:30 pm
SooperCooper on here bought a 1275 A Plus and box from Josh at Mini Imports, he holds stock, imports a few from UK or Japan I think.
We stripped it for rebuild and it was awesome, probably could have just run it!
It's now a stormin' 1360 with the Pearce Seven Port Head! :shock:
Mini Imports.... Recommended A1 :P
Sir Alec! we are not worthy!
PostPosted: Tue Jun 07, 2011 12:33 pm
Any idea on a price? I guess I am after a full unit to suite rebuild, ie including gearbox and diff ect.
PostPosted: Tue Jun 07, 2011 12:37 pm
I have an A+ block here , with steel center main cap , i also have 16v twin cam head here, & also have the conversion kit if you need it too
0407135656
Matt
edit--> Oh & i often buy power units from Josh, no problemos here
PostPosted: Tue Jun 07, 2011 7:36 pm
Oh and MadMatt the Miniman....
Recommended A1! :P
PostPosted: Sun Oct 09, 2011 9:32 pm
I have several A+ and A series 1275's for sale, I am in Mandurah, just send me a pm or email to discuss if you like.
68 Mini
70 Moke
Users browsing this forum: Bing [Bot] and 378 guests
