Where can I find a-plus blocks, short or long engines? https://www.ausmini.com/forums/viewtopic.php?f=2&t=71128 |
Author: | swervedriver [ Tue Jun 07, 2011 2:32 am ] |
Post subject: | Where can I find a-plus blocks, short or long engines? |
Hey, Just doing a bit of research for a race mini project I'm hoping to start quite soon. searched every site I can find and tried ebay for engines where do you guys find your engine's or blocks etc? Thinking a 1275 a+ for a start. Planning on doing a twin cam head conversion. I know specialist components sell these as turnkeys. Anyone had any experience with these? are they worth the money or could it be done a lot cheaper done locally or done by myself and mechanically inclined friends? Cheers for any help. Cory |
Author: | Convertible Mini [ Tue Jun 07, 2011 4:38 am ] |
Post subject: | A+ Blocks |
IF for racing... Just bare in mind that A+ blocks are stronger but heavier also. |
Author: | GT mowog [ Tue Jun 07, 2011 7:51 am ] |
A+ blocks in most ways are good, however, don't turn your nose up at a later non A+. The difference in strength is almost academic and lets face it, you're going to break a rod or crank way before you have any trouble or measurable difference with the block. Remember too that the A+ was not designed to give better strength than the previous blocks, they were intended to be quieter ![]() ![]() |
Author: | miniimports [ Tue Jun 07, 2011 8:23 am ] |
Post subject: | re aplus engines |
hi there cory have plenty of the aplus engines in all forms,ie blocks,short and long engines i am in melb but can freight anywhere around the country. speak to matt reid on here about the twin cam kit as he does a kit also, he will give you rough costings so you can make a comparison, cheers josh miniimports |
Author: | swervedriver [ Tue Jun 07, 2011 11:59 am ] |
How much heavier us the a+? I just read somewhere this was the better block for the k-series because it tiok heat better? And josh, do you regularly have these? This is just a bit of homework while I raise the cash.but if you have regular stock that helps a lot. What's the going rate for a good condition long engine a plus? Cheers mate. |
Author: | Wingman [ Tue Jun 07, 2011 12:18 pm ] |
I too have been looking for a 1275 for an upgrade down the line, have looked everywhere to no avail. |
Author: | graham in aus [ Tue Jun 07, 2011 12:30 pm ] |
SooperCooper on here bought a 1275 A Plus and box from Josh at Mini Imports, he holds stock, imports a few from UK or Japan I think. We stripped it for rebuild and it was awesome, probably could have just run it! It's now a stormin' 1360 with the Pearce Seven Port Head! ![]() Mini Imports.... Recommended A1 ![]() |
Author: | Wingman [ Tue Jun 07, 2011 12:33 pm ] |
Any idea on a price? I guess I am after a full unit to suite rebuild, ie including gearbox and diff ect. |
Author: | TheMiniMan [ Tue Jun 07, 2011 12:37 pm ] |
I have an A+ block here , with steel center main cap , i also have 16v twin cam head here, & also have the conversion kit if you need it too ![]() 0407135656 Matt edit--> Oh & i often buy power units from Josh, no problemos here |
Author: | graham in aus [ Tue Jun 07, 2011 7:36 pm ] |
Oh and MadMatt the Miniman.... Recommended A1! ![]() |
Author: | Smarty [ Sun Oct 09, 2011 9:32 pm ] |
I have several A+ and A series 1275's for sale, I am in Mandurah, just send me a pm or email to discuss if you like. |
