It is currently Sat Aug 23, 2025 7:26 am
 Post subject: id help
PostPosted: Sat Jun 11, 2011 3:17 pm
Ok, my car has these number stamped on the fire wall 24333 and its hard to read but i think the number on shroud is 2238z?!?!?!
Can anyoe help id this? As in year and model etc...
thanks
 Post subject: Re: id help
PostPosted: Sat Jun 11, 2011 7:36 pm
thanks
With that limited information, probably no.
Car shape?
Suspension type?
Door type?
Engine & transmission?
PostPosted: Sat Jun 11, 2011 8:06 pm
May be a silly question but have you checked the date code on the wiper motor?
82 BJ42 just completed resto
64 850 Modified(about to start rebuild)
PostPosted: Sat Jun 11, 2011 9:09 pm
just looked again
number on shroud is 23848
Car is a round nose with sliding windows. Currently has a 998 and rod change, haven;t looked hard yet but can't easily see and wand hole.
Number on wiper is 12V 75295E
DR2 3 60 A216
I will say that the number is stamped along the longer section on the wiper motor where as on my other mini it it stamped on the round section of wiper.
PostPosted: Sat Jun 11, 2011 9:13 pm
No doubt our resident "Mr Encyclopedia" on BMC models (Morris 1100) will respond shortly :P
PostPosted: Sat Jun 11, 2011 9:22 pm
Have a bit more of a poke around on the shroud to the left of what you've already found for the model number. There can be a fair bit of separation between the stampings for the model & car numbers. It'll be a 5 or 6-digit code, starting with Y.
PostPosted: Sat Jun 11, 2011 9:48 pm
Not if its an early car pre appox 69. although I think there may still be a code mark for the model elsewhere on the shroud usually something like..
M2
05
sometimes stamped in a circle.
The No on the shroud is the body No.
The No. on the firewall is the car number.
They are usually around 500 apart as Car no started at 501 and Body Nos. started at 001.
In this case the difference is 485 which sounds normal.
PostPosted: Sat Jun 11, 2011 10:33 pm
right....
just went out again and took another look...
scrapped and dug around, found
M2
05
stamped a bit further long the shroud towards the bulkhead.
So are we any closer to finding out what i have?!?!? lol
:D thanks
PostPosted: Sat Jun 11, 2011 10:46 pm
Blunder wrote:
right....
M2
05
:D thanks
Even though I used that as an example I can't remember what it is :lol:
I think it's Mini Deluxe.
Once you know the model then people with numbers knowledge can give an estimate on date.
PostPosted: Sun Jun 12, 2011 1:29 pm
lol...
So now i have seen:
M2
05
I'm closer but still not there...
Can anyone assist... thanks
PostPosted: Sun Jun 12, 2011 6:50 pm
Sounds like a 67 Deluxe, but not with sliding windows!
Could be an 850 with a replaced guard / shroud?
Which side is the bulkhead stamping on? does it have a magic wand gearlever hole?
Recheck your bulkhead number.....
Really need photo's :roll:
Sir Alec! we are not worthy!
Users browsing this forum: bharp831 and 298 guests
