It is currently Thu Jul 24, 2025 2:01 pm
PostPosted: Fri May 13, 2005 8:06 am
I bought a massisave JOB LOT today, I am searching throught the parts i have and i have so far found cooper S spedo's, brakes, boosters, S boxes, airfilters etc, so much stuff.
Anyway i am trying to distunguish a cooper S distrubtor apart from a standard.
I havent been in the mini game for a while, so some help would be good. I know the major differance is no vacume advance, But pictures and stuff would help.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Fri May 13, 2005 8:10 am
They are a 23D4, no vac advance, & have a long pin for the breaker points.
p/nos 40819B, or 40819H.
PostPosted: Fri May 13, 2005 8:43 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
kev cooper s dissy were twin point to wernt they ??
makka
PostPosted: Fri May 13, 2005 8:45 am
makka
NO. But they had 32oz points. :wink:
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i'm sure i was told that ........ owell
makka
PostPosted: Fri May 13, 2005 9:16 am
Not near my MkII at the moment,
so what are the part no.s for the MkII dizzys? I know they are quite different to all other mini dizzys in size(larger), but can't recall the number.
PostPosted: Fri May 13, 2005 10:01 am
My Clubby GT (with 1275S motor) had a 43D in it. :wink:
PostPosted: Fri May 13, 2005 10:25 am
Here is a picture of a 23D it might help.
I am running a 25D now and the main difference as far As I can tell is that the 23D does not have a vacuum advance but the 25D does. I used to have a 29D (special Aussie made version) 8)
 Post subject: 29D
PostPosted: Fri May 13, 2005 11:14 am
WHAT IS A 29D i have one of them as well?
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Fri May 13, 2005 11:41 am
The good Doctor could propably give you a full technical run down but as far as I know they are a "Made in Australian" version of the the 25D with the main difference being that the 25D has an external vacuum advance adjuster where the 29D does not. I have run both in my with my 1152 and they both preform about the same.
PostPosted: Fri May 13, 2005 1:34 pm
29D (with vac) was used on Mini K and early Clubbie. Then they changed to using 45D.
As far as S dizzys go, IMO they are overrated, and most now are probably worn out. These days points are passe. I bet a stock Pulsar electronic dizzy with it's std advance curve would make an S perform better than its original.
OK.. so it's not an item for concours cars.. :lol:
Users browsing this forum: Bill B and 105 guests
