It is currently Fri Aug 22, 2025 12:02 pm
 Post subject: what about these flares?
PostPosted: Sun Jun 19, 2011 12:32 am
hi guys, would someone be able to confirm that these will fit onto my clubby? It's not just rover is it?
Also does anyone have pics of these flares on the car side on?
Lastly will these accommodate 10 x 6 wheels? What about the innocenti ones? Will not be legal?
any help is much appreciated.
http://www.minisport.com.au/prod1416.htm
PostPosted: Sun Jun 19, 2011 12:40 am
Those flares will go on a clubby but the front ones will need a slight mod to fit neatly.
They're the same as the ones on Davo111s car.
They'll accomodate 10 x 6s easily, most people use them for 13 x somethings.
PostPosted: Sun Jun 19, 2011 7:41 am
lockie there is a leyland mini with the chrome edging & those cooper s flares
it's a rusty mini but has good flares painted yellow & the chrome trim engine is still on them! etc
he wants $350!! it's in brisbane i was thinking of going to check it out.
want his number? we can go check it together.
PostPosted: Sun Jun 19, 2011 7:47 am
Lochie, they are the same flares as i have on BALLISTIC. What wheels are you going to fit as it depends how far past the guard (wheel offset) they stick out to how wide you need the flares to be. Those flares are quite flimsy so I reccommend you make up metal backing (like they had on the cooper 's' & GT's) to help support them and you will need the wheel arch/flare trim to finish it off. (or you might get away with black pinch weld, i think clake rubber may still sell it).
http://www.minisport.com.au/prod44.htm
http://www.minisport.com.au/prod2110.htm
 Post subject: FLARES
PostPosted: Sun Jun 19, 2011 8:41 am
HI , IF THEY ARE THE SAME AS THE ONES FROM HUDDERHIELD THEY WILL FIT
PostPosted: Sun Jun 19, 2011 11:09 am
hi guys,
thanks for the replys, :)
Nick have sent you a PM :wink:
Harley, when you say slight mod of cutting, is this going to look dodgy? Is it to bend it into shape? I want it to be perfect that's all :lol:
Ballistic, I thought you had group 6 flares or something?
I'm not sure what wheels I want to go yet, but definitely 10 x 6's. The rears of the car have stepped drums, the front will just have 7.5 discs.
I currently have the plastic innocenti flares on atm, but with the 12 x 5's on it atm, they really only just cover the wheels, so I was wondering depending on the offset of the new wheels if I could keep these or not?
I also don't want these flares to look huge over 10 x 6's like I mean is this what people would recommend for the next size up, or we can't really know until I know exactly which wheels I'm going for?
Thanks for your help guys :)
PostPosted: Sun Jun 19, 2011 2:08 pm
I have a surplus set of those, never been used ;)
