It is currently Sun Aug 24, 2025 1:12 am
 Post subject: Idle drop and stalls
PostPosted: Sun Jun 19, 2011 6:17 pm
Just wondering if any one can tell me why when I put my headlights on the idle drops and sometimes when I stop at the lights too quick the car stalls
Thanks
PostPosted: Sun Jun 19, 2011 6:19 pm
You've conflated the symptoms.
Does the quick stop at traffic lights cause a stall all of the time or only when the headlights are on?
PostPosted: Sun Jun 19, 2011 6:22 pm
Tomboss Breweros
Maybe the idle is just a bit low, try it with the choke pulled slightly to bump the idle up.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Jun 19, 2011 6:33 pm
I'll start the car up it will idle fine then I put the headlights on and the idle just drops
PostPosted: Sun Jun 19, 2011 6:36 pm
That in itself is normal-ish. Mine does the same, but it is only a fractional change to the engine note. It's by no means getting close to stalling.
Again though, can you please clarify the "stopping at the lights" syndrome. Is that with or without headlights? It could be a red herring or it could be important, but the original description is ambiguous.
PostPosted: Sun Jun 19, 2011 6:37 pm
Is your battery charged..?
When I drive around with my headlights, and turn a corner and hit the gas, the car bogs down; If I turn the headlights off it picks back up and goes.
All battery related for me - Sounds similar
You're so square
Baby I don't care
PostPosted: Sun Jun 19, 2011 6:42 pm
The quick stop at the lights only stalls the car when the headlights are on
PostPosted: Sun Jun 19, 2011 6:46 pm
If the engine is otherwise tuned well and in good condition, I think Adam may be right; it's battery/alternator related.
After a long drive with the headlights on, do you ever have difficulty getting the car to start? Does the starter motor turn over slower than normal, even if it does start?
PostPosted: Sun Jun 19, 2011 6:56 pm
I'll have to try that out. Last time i drove it for a long time it was hard to start i jad to tirn everything off and start it.Thanks for the quick responses
PostPosted: Sun Jun 19, 2011 8:40 pm
Got a multimeter? Tap that on to your battery then get a helper to turn your lights on. See what happens!
Check your fuses as well. One of the cables might be loose. 2 fuses who thought that was a good idea!? :roll:
1978 Leyland Clubman S
Users browsing this forum: No registered users and 116 guests
