It is currently Wed Aug 20, 2025 12:19 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
PostPosted: Fri May 27, 2011 2:11 pm
Hi Guys,
Just had a phone call from the panel beaters and they he wont let me take my shell home on a car trailer with out the wheels attached. In fear of damaging the paint work . So he has offered his hoist and work shop so we can simply drop the subframes onto the body, so I can roll it onto the trailer, I know its a long way off, and not sure the date, but if anyone can assist It would be appriciated!
And I will let everyone know the date!
Should only be a few hours work. :D
Thanks Brett
PostPosted: Fri May 27, 2011 2:38 pm
I'm in. Let me know the details.
M
PostPosted: Fri May 27, 2011 2:43 pm
happy to help out, when needed :wink:
PostPosted: Fri May 27, 2011 3:35 pm
I'll help if available on the day.
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
PostPosted: Fri May 27, 2011 6:49 pm
Ill help if im available
Simplify and add lightness
PostPosted: Fri May 27, 2011 7:29 pm
Might be able to help, keep me updated.
PostPosted: Fri May 27, 2011 8:13 pm
if i'm not stuck under mine i'd be keen to come along, probably not much help, but i might learn something. :D
Dusk Blue
1964 850
 Post subject: help
PostPosted: Fri May 27, 2011 9:16 pm
Would be happy to come along and help out, im no mechanical genius but being a painter I've worked around more fresh paint than I could poke a ratchet at!
PostPosted: Fri May 27, 2011 9:57 pm
Thanks guys! I will def keep you posted.
Main things is before I can trailer it away is
* Fit subframes ( with all the bits attached already)
* Run Electrical cables I will try and do it the day before
* Fit windows and door locks so they dont flap all the way home.
Thanks so much guys! :D
PostPosted: Sat May 28, 2011 1:44 pm
Brake pipe are fitted before the subframes. :wink:
PostPosted: Sat May 28, 2011 1:57 pm
yes to right this! I found this out the hard way once. :lol:
PostPosted: Sat May 28, 2011 2:02 pm
And don't pinch the battery cable.... :mrgreen: (Lockie also found this out the hard way!
PostPosted: Sat May 28, 2011 2:25 pm
shhhhhhhh :oops:
PostPosted: Sat May 28, 2011 3:37 pm
NAV-MAN
shhhhhhhh :oops:
Well don't put it on a public forum then :roll:
PostPosted: Sat May 28, 2011 3:49 pm
shhhhhhhh :oops:
it will help others later down the track :wink: Plus at first never knew what it was.
Doesn't really bother me Matt, last comment to Morris was sarcasm. :wink:
Users browsing this forum: BIGGLES and 184 guests
